rca and power wires
Old Feb 23, 2006 | 10:27 PM
vidanator's Avatar
Default rca and power wires
when installing an amp, i read to keep the rca wires away from the power wire, well how far should they be away is what i'm wondering, because i want to run them both down the center, and they have about 3 inches of separation, is that good enough?
and another question, can i connect the front speakers to the amp by connecting wires from the amp to the front speaker wires from the factory harness, thanks
Old Feb 23, 2006 | 10:59 PM
Sex Cells's Avatar
Default Re: rca and power wires (vidanator)
i'd run them on opposite sides under the plastic piece that seperates the carpet from the outside (where you might rest your feet when you open the door, know what im talking about?)
Old Feb 24, 2006 | 05:44 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i'd run them on opposite sides under the plastic piece that seperates the carpet from the outside </TD></TR></TABLE>
They're called door sills... Or sill plates....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and another question, can i connect the front speakers to the amp by connecting wires from the amp to the front speaker wires from the factory harness, thanks
Yes, you can. I do it all the time. Definitely easier to run two sets of wires from the amp to the front than running wires into the doors... (especially if you've got a Honda with Molex plug)
Old Feb 24, 2006 | 03:36 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vidanator &raquo;</TD></TR><TR><TD CLASS="quote">when installing an amp, i read to keep the rca wires away from the power wire, well how far should they be away is what i'm wondering, because i want to run them both down the center, and they have about 3 inches of separation, is that good enough?
and another question, can i connect the front speakers to the amp by connecting wires from the amp to the front speaker wires from the factory harness, thanks</TD></TR></TABLE>
Buy a decent set of RCA cables and dont worry about it.
The same amount current the flows through the positive wire also flows through the frame of the car.
Old Feb 24, 2006 | 04:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: rca and power wires (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Buy a decent set of RCA cables and dont worry about it.</TD></TR></TABLE>Ditto that, but what you, [vidanator] also want the think about is length of any "wiring", always keep it as short as practical, run the RCAs and the speaker leads down the center of car, even the amp control lead can be run with the RCAs, run the power down the batt. side of car. 94
Old Feb 24, 2006 | 09:03 PM
VQMaxima's Avatar
its probably best to run the wires down oposite sides, but you could do it down the center just keep them as far apart as possible. when i did my car a few years ago i ran them down the center because i didnt know about this but i do have about 3-4 inches between the 2 wires and havent had a problem.
Old Feb 24, 2006 | 09:49 PM
Znypar's Avatar
if you're in a civic, you can run the RCAs straight down the center console, under the carpet, and under the rear seat with no problems and you wont see any wires. that will keep them seperate from your power wires as well.
Old Feb 25, 2006 | 09:15 AM
vidanator's Avatar
Default Re: (Znypar)
ok, thanks for all the replies, helped a lot
Old Feb 25, 2006 | 06:34 PM
TurboLaxx's Avatar
I ran my power wire down the passenger side under the sill plate and the RCA's down the middle under the center console. Just get some RCA's that are double or triple shielded. Mine are double shielded and they work just fine.
Andy_EJ8
Audio / Security / Video
Feb 8, 2011 12:02 PM
lee0149
13
Jan 7, 2009 08:47 PM
.Thomas
Jun 24, 2006 02:34 PM
imadigitalgod
11
Oct 30, 2004 12:32 PM
imadigitalgod
Oct 5, 2004 12:39 PM
