ef2 seats in an 88 crx si
will they work? if not what do i have to do to make them fit? can i just swap rails? thinkin of buyin a set and need to know what is involved before i grab them
You can make any seat fit any car, you just need to fit the factory seat brackets to the seat you want to put in your car. Or you can make a set of custom brackets, i've done this for customers and i'll run you less than $40 worth of steel from home depot. So if you have good or decent fabrication skills then go ahead and make a custom set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">You can make any seat fit any car, you just need to fit the factory seat brackets to the seat you want to put in your car. Or you can make a set of custom brackets, i've done this for customers and i'll run you less than $40 worth of steel from home depot. So if you have good or decent fabrication skills then go ahead and make a custom set.</TD></TR></TABLE>
correct
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-tec »</TD></TR><TR><TD CLASS="quote">good question im not sure. how can i tell the difference between the 2? what do you mean by swapping pans?</TD></TR></TABLE>
The bottom portion where the rails bolt onto.
spoon23_JDizM AkA SpOoN20
Aug 10, 2005 09:09 AM
