Tire size? Please help
hey guys I'm just wondering about this...what kind of problem am I going to run into if I get 205/55/15 for my LS meshies? Is there going to be rubbing? Slowing the car down? My car is lowered by 1.75" with 10mm spacers, and I did search and all I found was meshies with 205/50/15 tops. Can someone answer my question? Thanks a lot guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">205/55-15 is bigger than stock, and it might rub, particularly on a lowered car. Use 195/55-15 or 205/50-15 and you should be fine.
Go with 205-50's....they look better too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK VTi »</TD></TR><TR><TD CLASS="quote">hey guys I'm just wondering about this...what kind of problem am I going to run into if I get 205/55/15 for my LS meshies? Is there going to be rubbing? Slowing the car down? My car is lowered by 1.75" with 10mm spacers, and I did search and all I found was meshies with 205/50/15 tops. Can someone answer my question? Thanks a lot guys.
why are you running 10m spacers? do u have extended studs?
My bad....I have 5mm spacers to make the wheel base a little wider...got them for fre anyway, so why not? So I guess 205/55 is a bad idea then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK VTi »</TD></TR><TR><TD CLASS="quote">I have 5mm spacers to make the wheel base a little wider...</TD></TR></TABLE>
You mean the "track" (distance between a pair of wheels on opposite sides of the car), not the "wheel base" (distance between a pair of wheels on the same side of the car).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK VTi »</TD></TR><TR><TD CLASS="quote">got them for fre anyway, so why not?</TD></TR></TABLE>
Because it changes the suspension geometry and puts more pressure on the lugs and axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK VTi »</TD></TR><TR><TD CLASS="quote">So I guess 205/55 is a bad idea then?</TD></TR></TABLE>
Correct, 205/55 is a bad idea.
If someone is giving you tires and they're 205/55 and you want to use them up, go ahead and use them. (Hey, free tires are always a good deal!) But if you're buying tires, get 195/55 or 205/50.
Modified by nsxtasy at 11:47 AM 2/24/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK VTi »</TD></TR><TR><TD CLASS="quote">My bad....I have 5mm spacers to make the wheel base a little wider...got them for fre anyway, so why not? So I guess 205/55 is a bad idea then?</TD></TR></TABLE>
very bad idea, throw them in the trash. i work in a tire shop, and we wont even work on cars with spacers because they are so dangerous
CardDealer
15
Oct 6, 2005 03:51 AM
