What clutch do I need?
Old Mar 28, 2002 | 04:29 PM
VTECVillain's Avatar
Default What clutch do I need?
I'm putting a 96 LS motor into a 91 CRX and using a 92 LS cable tranny. Which year clutch do I need the 96 or the 92? Will the 96 flywheel work or do I need one from a 92?
Old Mar 29, 2002 | 10:35 PM
Bnjmn's Avatar
Default Re: What clutch do I need? (VTECVillain)
You will want to specify 92-93 for the clutch. I know the flywheel is identical, I think there might be something slightly different about the clutch kit with 92-93 vs. 94+ because the part #'s are different (800a vs. 800b on the Exedy).
Ben
Old Apr 3, 2002 | 06:26 PM
clutchcityonline's Avatar
Default Re: What clutch do I need? (Bnjmn)
Ben
The only difference between 800A and 800B is the throwout bearing. They both use same pressure plate and disc. Get a clutch kit for 92-93 (800A).
[Modified by clutchcityonline, 3:26 AM 4/4/2002]
Old Apr 4, 2002 | 07:21 AM
SCsol's Avatar
you will need a 92 clutch the FW from the 96 should worh fine
boosted 95 coupe
Sep 21, 2006 03:01 PM
96integraGSR
Aug 10, 2005 10:24 PM
onesikcivic
Dec 16, 2003 08:44 PM
VTECVillain
Jun 1, 2003 06:53 AM
