how do i wire up a tach with shift light on 92 civic
Old Feb 23, 2006 | 03:06 PM
B_gareiss's Avatar
Default how do i wire up a tach with shift light on 92 civic
Im trying to wire up a faze tach on my 92 civic ex 2 dr, can anyone help? ive heard you wire it off the distributor but im not shure
Old Feb 23, 2006 | 03:45 PM
zacatkings's Avatar
Default Re: how do i wire up a tach with shift light on 92 civic (B_gareiss)
does your car already have a tach? yes. Does honda have a reputation for bad tachs? no. Why fix something that isnt broken?
Old Feb 23, 2006 | 04:18 PM
Syndacate's Avatar
u don't have to jump all over him about it just because he wants an aftermarket tach....
It's mostly cosmetics, to make it look good..
As for the post, it has to be connecting the coil, not sure which wire it is, I'm not good with stuff like that, that's all I can say for that, I was just annoyed that he umped all over you for installing an aftermarket tach...like there aren't MILLIONS of them on civics with perfectly working tachs in the US AND Japan
Old Feb 23, 2006 | 05:20 PM
BlueIntegraBoy's Avatar
Your tach signal wire can come from the all BLUE wire behind your gauge cluster.
Old Feb 24, 2006 | 02:43 AM
Syndacate's Avatar
Default Re: how do i wire up a tach with shift light on 92 civic (BlueIntegraBoy)
will the "blue wire" still be there if your car doesn't have a tach (like there's no OEM tach in the cluster)
and
what do you do, splice it into the middle (create a 3-way junction area?, or jsut the two? (one from ignition to one from aftermarket tach)
Old Oct 1, 2008 | 09:46 AM
TeamRPM_ZC's Avatar
Default Re: how do i wire up a tach with shift light on 92 civic (Syndacate)
i have a x modole with no tach, just got an si cluster and plug in play (94 civic) and the wire is there, (blue)
Tyson
40
Jun 4, 2009 04:24 PM
littleblue
Nov 4, 2008 08:29 AM
esean93
Aug 23, 2008 10:33 AM
VTECsound
Jan 13, 2005 09:16 PM
NeedACivic
May 7, 2003 01:57 PM
