Break Rotors
Old Mar 28, 2002 | 04:18 PM
Tom Clancy's Avatar
Default Brake Rotors
Hi,
My brakes thump like hell whenever I stop. I had my rotors resurfaced once and the problem has resurfaced after 5,000 miles.
I would like to replace all rotors with aftermaket rotors. Does anyone have some suggestions as to what a good rotor/pad combination would be for me?
This is just for general driving no Auto-X.
thanks!
[Modified by Jessie Baine, 8:20 PM 3/28/2002]
Old Mar 28, 2002 | 04:20 PM
Tom Clancy's Avatar
Default Re: Brake Rotors (Jessie Baine)
AGHH.. I titled it Break rotors instead of Brake Stupid me!!
Old Mar 28, 2002 | 04:45 PM
matthewk's Avatar
Get Brembo OE's from http://www.collettimotorsports.com/ and and Axxis ultimate pads from Andie @ http://www.carbotecheng.com/main.htm
Old Mar 29, 2002 | 06:54 AM
bps2799's Avatar
Make sure you read about how to "bed in" the pads on the CarboTech website., as this procedure can save you 90+% of all brake warpage problems you will have.
Old Mar 29, 2002 | 07:45 AM
96IntegraLS4DR's Avatar
Default Re: Brake Rotors (bps2799)
Another thing I'd like to add.
Use torque wrench when tighten those lug nuts.
Unevenly tighened lug nuts can lead to rotor warpage also.
Old Mar 29, 2002 | 08:58 AM
bps2799's Avatar
Default Re: Brake Rotors (96IntegraLS4DR)
Esp. when you get tires mounted.
Trained monkeys often have more sense than the guys mounting the tires.
Just for the heck of it, I used my torque wrench and set it up in the high so not to damage it, then removed my lug nuts after getting new tires. Most were tightened to ~130-140 lbs-ft, judging by the break-over on the wrench. They were supposed to use a torque wrench, but they just put'em on w/ the impact wrench.
turbod96ex
Sep 25, 2003 03:28 PM
riceball777
Jul 22, 2003 03:49 PM
LudeyKrus
Jun 10, 2003 03:40 PM
brega3
Mar 15, 2003 02:36 PM
TsunamiZC
Jul 23, 2002 11:51 AM
