what should i look for before i buy a honda?
Old Feb 23, 2006 | 07:40 AM
notstreetlegal's Avatar
Default what should i look for before i buy a honda?
i really dont know what to look out for. i need your help
eg6sir-s's Avatar
Default Re: what should i look for before i buy a honda? (notstreetlegal)
find a good honda mechanic to help you look over the car before you buy it.
Old Feb 23, 2006 | 07:53 AM
sohc'd upEJ8's Avatar
Default Re: what should i look for before i buy a honda? (eg6sir-s)
Car Fax..........Try to find a clean body.......Good luck
Old Feb 23, 2006 | 08:01 AM
tallyturbo's Avatar
Default Re: what should i look for before i buy a honda? (sohc'd upEJ8)
if you cant get a mechanic do at least a compression check that way you know if your going to be getting a bum engine or not.
Old Feb 23, 2006 | 08:04 AM
jdm_sir2's Avatar
Make sure you knock on the fenders and parts of the body to make sure some parts aren't bonded up and that it all sounds the same and it does leak oil from the seals and from the valve cover and from the tranny and that the tranny doesn't feel sluggish or grinding in any gear!
Vague
Apr 20, 2015 05:16 AM
Eighty-Nyne
Aug 28, 2009 12:42 AM
Working Class
Transmission & Drivetrain
Aug 26, 2009 12:06 PM
JDMjoe86
Mar 22, 2008 09:22 PM
