EG/Del Sol adapter hub on an EF
Old Feb 23, 2006 | 07:07 AM
downest's Avatar
Default EG/Del Sol adapter hub on an EF
I pulled a MOMO wheel from a Del Sol at a junkyard yesterday, but I couldn't get the hub off. I'm going back today with a puller to remove it. Will the hub adapter work on my CRX? It's a 6-bolt wheel.
Old Feb 23, 2006 | 07:19 AM
rsca_crx's Avatar
Default Re: EG/Del Sol adapter hub on an EF (downest)
i don't know for sure since i've never had to try it, but i did have a eg (might have been dc?) oem steering wheel on the red car to push it around the garage for a while, so i'm pretty sure the splines are right. what else changes?
what yard are you at?
Old Feb 23, 2006 | 07:21 AM
downest's Avatar
Default Re: EG/Del Sol adapter hub on an EF (rsca_crx)
Thanks Greg, John told me it won't fit, which is why I'm asking. I'm still going back to get it anyway. Here's a pic of the wheel, if anyone can identify it:
Old Feb 23, 2006 | 07:41 AM
beyondspexj's Avatar
no it wont fit. ef's and DA's work. but eg and dc wont because they have a different hub. its only longer or shorter i cant remember which. but i remember it had to do with the fact that they came with airbag equipped steering wheels. i believe using the eg/dc one will sit the wheel too close to your combonation switches ( turn signals and what not )
Old Feb 23, 2006 | 08:06 AM
rsca_crx's Avatar
Default Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar &raquo;</TD></TR><TR><TD CLASS="quote">no it wont fit. ef's and DA's work. but eg and dc wont because they have a different hub. its only longer or shorter i cant remember which. but i remember it had to do with the fact that they came with airbag equipped steering wheels. i believe using the eg/dc one will sit the wheel too close to your combonation switches ( turn signals and what not )</TD></TR></TABLE>
that makes sense, but you might as well grab it ans at least sell it if the yard lets you keep it. are you at one of places up rt7?
nice find on the wheel either way.
Old Feb 23, 2006 | 08:44 AM
downest's Avatar
Default Re: (rsca_crx)
Yeah, I went to both of the big ones up 7. One of them has a really clean STD hatch, motor works and everything, just has a broken control arm in the rear.
Old Feb 23, 2006 | 09:18 AM
downest's Avatar
Default Re: (downest)
So it will go on, just be at a different position? If it sticks out farther (seemed to on the sol) that's actually what I want. Could I use it together with a quick release?
Old Feb 23, 2006 | 09:54 AM
you gotta remember a quick release is going to stick it out even further depending on the brand. just get the hub for the ef and then the quick release. then it should be set as far out as your looking for.
305_DB7ish
May 5, 2015 05:21 AM
8dxhatchy8
Feb 23, 2009 10:22 AM
nsxmatt
Aug 15, 2008 06:46 AM
crxd16
Aug 15, 2007 12:40 PM
JapJunkie
Jun 24, 2004 11:06 AM
