f20c into eg possible?
Old Feb 23, 2006 | 03:01 AM
1sikhatch's Avatar
Default f20c into eg possible?
i would like to know if a f20c (s2000 motor) will fit in a eg? if it would, will i have to use prelude, mounts axles, tranny ect? also if any one has a write up on this can u post it.
Thanks
Old Feb 23, 2006 | 04:11 AM
6SPD_EK's Avatar
Default Re: f20c into eg possible? (1sikhatch)
no it won't...you'll need one off mounts, one off custom bellhousing (to keep FWD), one-off wiring one off everything like $20,000 in one-off ****
NO prelude **** will bolt to s2000 **** - lol
just get a k20a/k24a
Old Feb 23, 2006 | 05:32 AM
1sikhatch's Avatar
Default Re: f20c into eg possible? (adirondackR)
ok so the f20c is definently out of the question, what about the f20b?
Old Feb 23, 2006 | 05:46 AM
6SPD_EK's Avatar
there is no relation between f20c & f20b....why would you want a f20b you would need a lot of custom **** to get a f20b too
"what about a k20 or k24"
Old Feb 23, 2006 | 05:57 AM
darkcvc's Avatar
Blue Sedan Crew
the f series from the S2K would have to be custom, every part of it.....
Old Feb 23, 2006 | 06:00 AM
slotec's Avatar
Default Re: f20c into eg possible? (darkcvc)
f20b will fit its pretty much having an h22 in an eg. f20b is same as h22 jus has higher compression, more aggressive cams, and a 2.0L
Old Feb 23, 2006 | 06:05 AM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">ok so the f20c is definently out of the question, what about the f20b?</TD></TR></TABLE>
F20C is out of the question. Just trash that idea.
F20B will theoretically work, but why? IMO thats a very unpractical engine, if you want to do a big swap like this why not just go K-series.
Old Feb 23, 2006 | 06:21 AM
6SPD_EK's Avatar
Default Re: f20c into eg possible? (slotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">f20b will fit its pretty much having an h22 in an eg. f20b is same as h22 jus has higher compression, more aggressive cams, and a 2.0L</TD></TR></TABLE>
yes....& a H22 will swap more easily or if you have $$ go K...or go B lol
Old Feb 23, 2006 | 06:32 AM
instrument's Avatar
blahblahblah
Old Feb 23, 2006 | 09:00 AM
. a d a m's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">blahblahblah</TD></TR></TABLE>
Thanks for your contribution
Old Feb 23, 2006 | 09:42 AM
1sikhatch's Avatar
h22, f20b and the k20 have more or less the same hp and tq and i was thjinking about getting the f20b cause most people get the h22 but i wanna get someting a lil different. and the f20 is easier and cheaper than the k.
Old Feb 23, 2006 | 06:25 PM
slotec's Avatar
Default Re: (1sikhatch)
it wil be just as much work but it will be significantly cheaper than a K and tuning
Old Feb 24, 2006 | 11:05 AM
instrument's Avatar
i figured blahblahblah was as likely to happen as a f20 engine going into his car.
lets think about the question...and the rational behind it....
Old Feb 24, 2006 | 12:22 PM
swatteamtimmah's Avatar
probaly your best bet is to put a rb26tt and convert to awd.
*sarcasm.
Old Feb 24, 2006 | 05:35 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i figured blahblahblah was as likely to happen as a f20 engine going into his car.
lets think about the question...and the rational behind it....</TD></TR></TABLE>
Anything can be done if you have enough money.
An F20C wouldn't work unless he had alot of money and a crazy fabricator..but for that money he could just have an S2000.
An F20B WOULD work. I don't see why its not feasible to do this, as stated above its basically the same as an H22. Sure, it would take some fabbing, and a k-series swap would be a more wise way to spend money, but it could be done.
Old Feb 24, 2006 | 05:51 PM
The_Head's Avatar
F20B and H22A blocks share the same external dimensions, pretty sure. It's just that the F20 uses iron sleeves and an 85 mm bore. It uses an H22A crank, but its's been offset ground to reduce the stroke to 88 mm.
Pretty sure the heads are the same too, but different IM, and slightly different cam proflie. Someone correct me if I'm wrong.
Old Feb 24, 2006 | 05:53 PM
. a d a m's Avatar
Default Re: f20c into eg possible? (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">F20B and H22A blocks share the same external dimensions, pretty sure. It's just that the F20 uses iron sleeves and an 85 mm bore. It uses an H22A crank, but its's been offset ground to reduce the stroke to 88 mm.
Sounds about right if I'm not mistaken
Old Feb 24, 2006 | 10:09 PM
Ape's Avatar
Ape
lawl. Reminds me of my sig.
Old Feb 24, 2006 | 11:06 PM
nello a.'s Avatar
just get a k and call it a day.
Old Feb 25, 2006 | 09:05 AM
slotec's Avatar
Default Re: (nello a.)
i think the f20b has more torque and would be ur best bet, also very original
Old Feb 25, 2006 | 04:13 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">just get a k and call it a day.</TD></TR></TABLE>
Best response yet
Old Feb 25, 2006 | 04:19 PM
The_Head's Avatar
Default Re: (Sh!ttyLS)
Come on. People don't get K's because they're really expensive.
Old Feb 25, 2006 | 06:47 PM
Bense's Avatar
22 posts and nobody has given a legit response.
the f20c spins in a different direction than all the other honda motors. (f20c + h22 tranny = REVERSE!)
However since the k-series spin in the same direction there has been somone that ran an adapter plate on the f20c to run a k20 tranny all with custom mounts.
Yes it is possible. But it's not really feasible.
Another thing. I hate how everyone just throws about "just get a k and call it a day" The swaps are like 8000 dollars. Nobody wants to spend that much on a swap. Why? Because it's a 2000 dollar car with an 8000 dollar drive train. Good luck selling it for what you "invested" It's cheaper to just go turbo ls and you get better numbers in the end.
Old Feb 25, 2006 | 08:37 PM
The_Head's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">It's cheaper to just go turbo ls and you get better numbers in the end.</TD></TR></TABLE>
But I want to have something unique and cool I don't want to be another bandwagon Honda guy! Wait, I own an "EG" Civic, er, well, nevermmind.
Old Feb 26, 2006 | 05:59 AM
6SPD_EK's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">22 posts and nobody has given a legit response.
However since the k-series spin in the same direction there has been somone that ran an adapter plate (a $10,000 prototyperacing custom bellhousing) on the f20c to run a k20 tranny all with custom mounts (in a lotus exige)
Yes it is possible. But it's not really feasible. Yes - which is why prototyperacing never made a production run of the bellhousing - they switch to K-series motors for many reasons
Another thing. I hate how everyone just throws about "just get a k and call it a day" The swaps are like 8000 dollars. Nobody wants to spend that much on a swap. Why? Because it's a 2000 dollar car with an 8000 dollar drive train. Good luck selling it for what you "invested" It's cheaper to just go turbo ls and you get better numbers in the end.</TD></TR></TABLE>
I will never sell my car - I will gut the **** out of it & make a track **** before I sell it...you never know a 250whp K could whoop a LS turbo too
