jdm b20 on its way
Old Mar 28, 2002 | 01:15 PM
1stealthls's Avatar
Default jdm b20 on its way
i ordered my b20 yesterday from steve at hondamotorsonline got a good
deal 975 shipped from cali to ohio 12k miles i cant wait to put it in it will be here next friday im so happy
[Modified by 1stealthls, 7:05 AM 3/29/2002]
Old Mar 28, 2002 | 03:46 PM
speedillusion's Avatar
New User
Default Re: jdm b20 on its way (1stealthls)
just for the b20 motor? when you get your motor. can u give me an update? i'm planning on doing the same transplant. if it was worth it, good customer service. etc. thanx man, and good luck.
Old Mar 28, 2002 | 10:08 PM
1stealthls's Avatar
Default Re: jdm b20 on its way (midnitekreeper)
i will inform u when i do the swap we r doing my friends b20 first it is going in a 2nd gen teg
Old Mar 29, 2002 | 06:34 AM
Adam.'s Avatar
was it just the long block?
Old Mar 31, 2002 | 07:17 AM
Ri5e's Avatar
Default Re: jdm b20 on its way (DarkKnight[DMD])
For that much money, you could've gotten your block resleeved with ductile iron sleeves, and bored to 2.0 liter. Would've been more "stealth" that way.
Old Mar 31, 2002 | 10:45 AM
1stealthls's Avatar
Default Re: jdm b20 on its way (BG Boost)
well i could have done that .........but my ls motor is gone i spun the #3 rod bearing(completly gone) that caused the piston to hit the head (destroyed the head) the crank was salvagable that was about it. i would had to buy an ls motor which is 700-900$ which probably came out of a car with 60k-100k miles
that is why i bought the b20 146hp 133ft lbs tq which has thicker cylinder walls and low enough compression to run 7-10 psi of boost (reliable boost w/ proper tuning)
plus it is something that not that many people have done i like to be different
maybee my dyno sheets will make u realize why i didnt stay 1.8l
jdm b20 with 18k miles for 975 shipped to ohio tell me who would pass up that deal if that is what they wanted
Old Mar 31, 2002 | 04:17 PM
Flexmyrex's Avatar
im looking into the same setup, it will be going into my 88 crx.
Can anyone give me some more info on this, what ecu ? tranny? i have also heard that i will be needing teg mount brackets. any other input will be appreciated. thnks in advance.
Old Mar 31, 2002 | 07:35 PM
C1V1C's Avatar
Default Re: jdm b20 on its way (flexmyREX)
SIR cable tranny, teg LS ECU, its basically the same as any B series swap.
Old Mar 31, 2002 | 11:15 PM
dlric's Avatar
about the teg mount brackets: the driver side and rear tranny mount brackets on the actual longblock need to be swapped out in favor of DA (90-93) teg brackets if you're doing a b18B/b18C (pretty sure on the gsr) or b20B/b20Z swap into a crx. this is if you are using hcp/hasport mounts. im not 100% sure about the rear tranny bracket..but im 99%. i just havent done the swap yet to verify the other 1%. i've seen actual pics i think superhatch posted on here showing the differences in the b18b and b18a driver side mount brackets so im 100% sure for that. for whatever odd reasons this is a fact that isn't really mentioned in the various resources we have..and ppl dont talk about it much. but there you go.
Old Apr 3, 2002 | 04:51 PM
StorminMatt's Avatar
Resleeving and boring alone costs about $900. But this doesnot take into account the cost of the pistons, which typically go for another $500 for a good set.
Old Apr 10, 2002 | 08:43 PM
MugenGTR's Avatar
Default Re: jdm b20 on its way (StorminMatt)
i actually got a jdm b20b longblock from steve at hondamotorsonline.com also. customer service is GREAT! i actually went down to his place and picked up the motor. There were like 12 b20's jus sitting there on the floor! he let me pick the one i wanted as well. i only paid $800 though since i picked mines up. had the motor for about a month now and been swapping wiring harness, distrubutor, intake manifold, cams, tranny, clutch, and everythin else i could salvage off my blown b18b motor. the motor is gonna get dropped in this friday so we'll jus see wat happens. wish me luck!
tepasoelrolo
Jun 23, 2009 04:24 PM
90civicturboed
Oct 8, 2005 07:09 PM
Jmorin
Mar 18, 2004 06:40 PM
1stealthls
Nov 6, 2002 01:22 PM
