crx dash in hatch.need info on a plug.
Old Feb 22, 2006 | 05:46 PM
d16efsedan's Avatar
Default crx dash in hatch.need info on a plug.
behind the center console where the radio goes there is a little yellow plug with i think 4 wire,just wondering what it was for?TIA Brian
Old Feb 22, 2006 | 11:42 PM
d16efsedan's Avatar
Default Re: crx dash in hatch.need info on a plug. (d16efhatch)
BUMP...anyone??
Old Feb 22, 2006 | 11:50 PM
downest's Avatar
Pics? Maybe it's the clock or cigarette lighter.
Old Feb 23, 2006 | 12:14 AM
d16efsedan's Avatar
Default Re: crx dash in hatch.need info on a plug. (downest)
best pic i can get at the moment...
Old Feb 23, 2006 | 12:35 AM
d16efsedan's Avatar
its not a plug for the lighter cause it has 4 plugs the lighter is only 2.and it dont reach to the clock...
Old Feb 23, 2006 | 01:28 AM
4thgenhtch's Avatar
Did it Come off the heater control or maybe the ac switch.. Thats about all it could be besides the previously stated
Old Feb 23, 2006 | 03:46 AM
hatchblack's Avatar
if you are swapping the crx dash into the civic, there should be no wiring involved. that plug should remain in the crx and should be nothing you have to worry about. i don't remember seeing that plug when i swapped a crx dash into my civic.
Old Feb 23, 2006 | 09:53 AM
d16efsedan's Avatar
Default Re: crx dash in hatch.need info on a plug. (hatchblack)
hmm could be a old ac plug since i removed the a/c....ill be ripping the dsh out to the to the bottom of it... thanks
Old Feb 23, 2006 | 09:55 AM
d16efsedan's Avatar
ok probably the a/c plug since i removed it,i'll be rippin the dash out to get to the bottom of this...
Old Feb 23, 2006 | 10:31 AM
Broke EF's Avatar
I swaped a 91 CRX Si dash into my car and the wiring was slightly different form my 90 Std hatch. The only 4 wire yellow plug I saw was above the fuse box but I cut off the wiring I wasnt using IE the radio and heat/ac. The one thing that was different was the clear/white plug for the fuse box. On the CRX harness it was wider and had an extra wire. I was gonna use the civic dash harness but it was hacked to **** and wasnt working so I pinned out that connector and used the CRX harness and now everything is fine . You can always swap the wiring if that makes it eiser.
Sean
Old Feb 23, 2006 | 10:35 AM
Concept Tuning's Avatar
I'm confused why your worrying about wiring if your just doing a dash swap.
Old Feb 23, 2006 | 01:55 PM
d16efsedan's Avatar
Default Re: (Concept Tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Concept Tuning &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused why your worrying about wiring if your just doing a dash swap.</TD></TR></TABLE> im not worried about it and the dash swap has been done for almost a yr now,i was just wondering what it was for and after further inspection it was for my a/c button with i removed and replaced with a block off plate.........thats alll thanks for everything everyone.
stinkypinky1011
Honda CR-V & Element
Mar 28, 2016 05:02 PM
mortificationrock
11
Dec 31, 2011 01:08 PM
motoxx644
Jun 9, 2008 12:27 PM
BUCK_NASTY
Dec 5, 2007 11:39 AM
