Rear Main Seal Leak...Or Is It?
Old Feb 22, 2006 | 03:37 PM
mntdewred's Avatar
Default Rear Main Seal Leak...Or Is It?
Few days ago I started to notice little oil spots on the ground where I usually park. After looking around underneath the car, I found where it drips from. It drips from where the tranny and the engine block meet. However, I also noticed moisture near the passenger side axle. Also another little fact is that this is CLEAN oil. I waited for a drop to form and then I swiped it with my finger. It wasn't normal dirty motor oil, it was relatively clean. I did an oil change about 2200 miles ago and I did another one tonight.
At first I thought the rear main seal decided to give, but now that I see that the oil dripping is clean, I don't know what to think.
Any suggestions? I'm stumped. TIA
Old Feb 22, 2006 | 03:47 PM
eGriDin's Avatar
dude possible rear main, or most likely ur oil pan gasket, those are the only to seals in that area, make sure its not coming from the top of the engine..
Old Feb 22, 2006 | 06:23 PM
mntdewred's Avatar
Default Re: (eGriDin)
Yea, but if that was the case don't you think the leaking oil would be the normal, dirty, dark color of oil? This was like I just opened a new bottle of oil kind of clean.
I let a drip form where its dripping from and swiped it with my finger and it was clean. I swiped the ground where it was dripping and again, it was clean oil.
mntdewred's Avatar
Default Re: (mntdewred)
And from what I can tell, there is nothing leaking from the top of the motor.
Old Feb 22, 2006 | 11:16 PM
wwang924's Avatar
Could be from the tranny? Passenger axle, oil from the transmission would be fairly clean.
Old Feb 23, 2006 | 02:29 AM
mntdewred's Avatar
Default Re: (wwang924)
Thats what Im thinking, but where the drips are forming, its hard to say its coming from the axle.
Old Feb 23, 2006 | 04:52 PM
mntdewred's Avatar
TTT
Old Feb 23, 2006 | 04:55 PM
.Ry's Avatar
.Ry
Pictures are the only way we can know.
Old Feb 27, 2006 | 01:14 PM
zerobacan's Avatar
Default Re: (turner7205)
the oil leaking from the Engine Rear Main Seal is pretty clean, because is doesnt pass for any dirty part of the engine... and im having the same leak, and its pretty clean too.
Old Feb 27, 2006 | 01:28 PM
pinoyboiwonder's Avatar
i have the same problem dont mean to jack your thread but yea where my tranny meets the block i see little droplets ready to fall.. i dont know if its coming from the tranny or w/e.. if i get pics of my problem please help me out in this thread.. which could potentially help him too! thanks!
Old Feb 27, 2006 | 01:31 PM
bostoncal's Avatar
same here..more likely its the rear main seal...im doing a swap anyways so just keep adding oil for now.
Old Feb 27, 2006 | 01:42 PM
hondamark35's Avatar
Default Re: Rear Main Seal Leak...Or Is It? (mntdewred)
rear main is a possiblility. so is the Dist. O-ring, the VC gasket, the vtec solenoid (if app.), and the oil pan gasket.
prob. the best thing to do to narrow it down is to get the engine bay good and clean and then look for leaking. also monitor your oil level as often as possible.
Old Feb 27, 2006 | 01:52 PM
Braco11's Avatar
Default Re: Rear Main Seal Leak...Or Is It? (hondamark35)
sounds like the rear main. i have the same problem too.
Old Feb 27, 2006 | 02:19 PM
whats the rear main? how does it look like?
Old Mar 1, 2006 | 06:34 PM
eGriDin's Avatar
Rear main looks like a cam seal, or like a crank seal, but with a bigger diameter, have to remove tranny, clutch & flywheel...so if ur gonnna change..upgrade those things also..if u want while the tranny is out...
Old Mar 1, 2006 | 06:46 PM
mntdewred's Avatar
I don't see how oil leaking from the rear main seal can be clean. That doesn't make any sense.
However, it would make sense that cleaner oil would drop from the transmission. I replaced one of the bearings in my transmission back in August and I didn't change that oil seal that sits next to it. I have a feeling its the oil seal in the tranny thats bad.
Either way, the tranny has to come off. So we'll see what happens when the weather gets warmer.
05foresterxt
12
Dec 30, 2010 03:59 PM
kornerk12
Oct 8, 2008 06:36 AM
SKDRCR
Jul 2, 2004 02:27 PM
serious
Mar 23, 2004 10:03 AM
krshultz
Feb 4, 2002 05:07 PM
