Suspension & Brakes Theory, alignment, spring rates....
rear lower tie bar ?
Old Feb 22, 2006 | 03:29 PM
typesguy's Avatar
Default rear lower tie bar ?
wassup i got a rear lower tie bar being shipped to me but i wanted to know if it's goona mess my alignment up in the rear if i install it.
Old Feb 22, 2006 | 04:15 PM
TunerN00b's Avatar
Default Re: rear lower tie bar ? (jaydmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">wassup i got a rear lower tie bar being shipped to me but i wanted to know if it's goona mess my alignment up in the rear if i install it. </TD></TR></TABLE>
How could it possibly change the alignment?
The answer is, no. Unless you start actually changing things that will effect the alignment (ride height, toe adjusters, camber adjusters if you have any installed) your alignment will be the same.
Old Feb 22, 2006 | 04:42 PM
Tornadom's Avatar
It will not change your alignment.
Old Feb 22, 2006 | 04:51 PM
alwaysoverkill's Avatar
I think he is talking about when he removes the rear LCA bolt to hook up the tie-bar
Old Feb 22, 2006 | 05:08 PM
byronl's Avatar
what if you remove the whole lower control arm would it mess up the alignment? I had to do that to get the dam thing to align when i installed my tie bar
Old Feb 22, 2006 | 08:32 PM
Elwuudz's Avatar
buy some coffee and latex gloves for the long install on this1
my lower rear tiebar took 10 min to install and made a noticable reduction in body roll
it didnt change my alignment at all, just made the ride stiffer in the back
always have someone with experience QC ur work
the shop didnt even charge me for the lift time since it was so quick
good luck with ur ride
Old Feb 22, 2006 | 10:20 PM
Hawkze_2.3's Avatar
Default Re: rear lower tie bar ? (Elwuudz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">my lower rear tiebar took 10 min to install and made a noticable reduction in body roll
How in hell did it reduce body roll?! It's not a sway bar, it's just a useless brace.
Old Feb 22, 2006 | 10:21 PM
FULL throTTLe's Avatar
i don't think it would, i took my whole lca off to put on a new one, and my car rides straight still
Old Feb 23, 2006 | 01:53 PM
dfoxengr's Avatar
Default Re: rear lower tie bar ? (Hawkze_2.3)
it cant reduce roll, only a roll bar can do that. it does however prevent some flex...i saw a difference when i put mine on.
Old Feb 24, 2006 | 11:45 PM
willywong's Avatar
yeah the lower tie bar doesnt effect roll or alignment in any way.. the lca inner bolt is just a staight pivot not like other types which have essentric bolts that adjust toe. i have jic front and rear tie bars and the steering response is noticably better, but roll is the same.
sol_1
Feb 25, 2007 05:30 PM
burplelude
Mar 24, 2006 07:27 PM
dasistheone
Mar 3, 2006 05:45 PM
92LudeSI
Jun 19, 2004 12:47 PM
Hapa88
Apr 13, 2003 01:35 PM
