LS build up
Old Mar 28, 2002 | 12:26 PM
hybrid901's Avatar
Default LS build up
I have a customer who is wanting to build his b18b all motor. I have never built a LS motor before for all motor. Will any factor pistons work with the LS head or will all the valve reliefs be off? What needs to be done to make 155-165 whp? I was thinking .20 over 11:5:1-12:1, eagle rods, skunk mani, crower cams or zex cams. Will he need a port and polish job to reach this power level?
Thanks
Old Mar 28, 2002 | 02:06 PM
Westrock2000's Avatar
Default Re: LS build up (hybrid901)
CTR or ITR pistons (JDM ones)....give ~11.5 CR in stock LS. Have em try the new 62402T's and see how those work for all motor, <U>lots</U> of lift but not very much more duration than stock.
Old Mar 28, 2002 | 02:38 PM
jdmciviceg's Avatar
New User
Default Re: LS build up (Westrock2000)
I didn't think itr or ctr pistons work work. Is there any problem with the valves and pistons touching? I was under the impression the valve reliefs are slightly different.
Old Mar 28, 2002 | 02:49 PM
ALF's Avatar
ALF
Default Re: LS build up (jdmciviceg)
You should IM 97blackteg on this board. He has a built LS motor using ITR pistons.
i heart honda
Mar 21, 2006 10:52 AM
2uy
Sep 14, 2005 02:42 PM
volcom40street
12
Dec 17, 2004 10:59 AM
Halo
Sep 18, 2001 08:25 AM
