shatty shifter
Old Feb 22, 2006 | 02:14 PM
CTR-GSR's Avatar
Default shatty shifter
I just installed prothane shifter bushings on my car and my shift feels a lot more positive. However, my shifter still moves horizontally while in gear a lot. I know which bushing needs to be replaced but does anyone know what the part is called so that I can order them?
Old Feb 23, 2006 | 04:46 AM
CTR-GSR's Avatar
Default Re: shatty shifter (SLOW guy)
http://www.hondaautomotivepart...LEVER
On this diagram, I changed the bushings for #14 and #18, yet my shifter still moves side to side. What else needs to be changed.
Old Feb 23, 2006 | 06:01 AM
sicones's Avatar
Default Re: shatty shifter (CTR-GSR)
nothing, only a short shifter will limit that movement
Old Feb 23, 2006 | 06:02 AM
. a d a m's Avatar
Default Re: shatty shifter (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">nothing, only a short shifter will limit that movement </TD></TR></TABLE>
Old Feb 23, 2006 | 08:36 AM
nocturnaldragon's Avatar
Check the clearance between the shifter and the rob, it should be tight, if not put some washers in there to tighten it up.
Old Feb 23, 2006 | 06:11 PM
CTR-GSR's Avatar
Default Re: shatty shifter (nocturnaldragon)
good idear!!
Old Feb 23, 2006 | 06:42 PM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR-GSR &raquo;</TD></TR><TR><TD CLASS="quote">good idear!!</TD></TR></TABLE>
http://media.putfile.com/Sloppy-shifterbooo
nothing beats my sloppy shifter...changed the #14 bushing today..i felt a lil diff..when shifting..but still moves/twists the same as before..im going to change 16 when i get some free time..
Old Feb 24, 2006 | 09:47 PM
CTR-GSR's Avatar
Default Re: shatty shifter (WhiteOut)
I gotta check out how bad ur shifter is if you go to the one6 meet in march
dRoPpEd lS
Mar 9, 2009 09:02 PM
I Am White
Mar 14, 2007 07:15 PM
ProjectCD5
Feb 21, 2006 11:55 PM
gameknb
Jun 11, 2005 07:32 AM
