DC tig welding aluminum...
Old Feb 22, 2006 | 01:10 PM
*Boostwerks*'s Avatar
Default DC tig welding aluminum...
I am trying to get as much information on this as possible. I have found that if I use Ultra High purity helium as a sheilding gas, I can effectively weld aluminum with DC. I'm just wondering if anyone has anymore information on this? I'm kinda wondering exactly what gas I would need to buy, and how much it should cost for say a 40cf cyl. My maxstar STH also has adjustable pulsing capabilities, which should help.
I would be welding .125" thick aluminum. If it doesn't work, thats ok but I would like to try this out if it is at all possible.
Thanks for any info!!!
Bryson
Old Feb 22, 2006 | 03:31 PM
k24em2's Avatar
Default Re: DC tig welding aluminum... (Bryson)
Welding .125 aluminum with DC and UHP helium is overkill. Typically thick sections of aluminum are welded on DC. (>1") I'm not saying it can't be done, but it will be tough to get it to work right. Helium costs here are about triple the cost of argon, and you have to have you CFH about three times higher to maintain proper coverage since helium is lighter than air and tends to float away.
Old Feb 22, 2006 | 07:07 PM
Default Re: DC tig welding aluminum... (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Welding .125 aluminum with DC and UHP helium is overkill. Typically thick sections of aluminum are welded on DC. (&gt;1") I'm not saying it can't be done, but it will be tough to get it to work right. Helium costs here are about triple the cost of argon, and you have to have you CFH about three times higher to maintain proper coverage since helium is lighter than air and tends to float away.</TD></TR></TABLE>
Yeah, from what I've looked into so far, it seems like I might be better off if I just rent an AC/DC machine, if thats even possible. If not, I will just have to use steel for my project.
Old Feb 24, 2006 | 03:22 PM
Bjorn's Avatar
out of curiousity, do you do DCEP or DCEN - I've tried DCEN and it just smokes black ash (like when you mig AL), but have always wanted to try DCEP. Any pics?
Old Feb 24, 2006 | 08:02 PM
k24em2's Avatar
Default Re: (Bjorn)
DCEN.
BETO_20DA
Lighting
Jun 15, 2010 01:30 AM
poweredbyb16
Welding / Fabrication
Apr 16, 2009 06:59 PM
