INFO ON THROTTLE BODYS FOR A Y8
The only time an upgrade throttle body helps any is when you have other stuff done to your car and if you get a bigger one it's not going to do anything unless you port match it to you intake manifold!
easy on the caps lock. best throttle depends on your other mods, your budget, and several other things. dont forget, you must port match the throttle body opening in the intake mani if you get a bigger throttle body.
i have intake,header,catback,hi flow cat, light weight flywheel and some other stuff i'm just looking to see if i can bolt on a b-series or h-sreies or something. i'm trying to up grade without spending to much money.
