99 Prelude front dash assembly diagram?
Hello, anyone has a 99 Prelude front dash assembly diagram that you can point me to. There is this squeaking noise coming from the passenger side SRS cover and the dash area right above the center A/C air vent. It only squeaks when weather is cold. When the sun shines on the dash for a minute, the squeaking noise goes aways. But it's very annoying driving when the dash is cold. Anyone has a front dash assembly diagram??? I'd like to take the dash apart and put some WD40 on the moving parts
. Please help. Thanks.
The center part w/the clock on it just pops off. There's clips holding the sides if I remember correctly. You'll probably want to use a panel clip removing tools or a wide flat head screw driver. Sorry, I can't help much on the SRS part tho.
