FS: water pump, oil pump, timing belt, VC gasket, oil filters, seals, AND MUCH MORE
After a few years of owning numerous honda's i've got a bunch of extra parts laying around that I've never used. mainly maintence type of stuff in this thread, i'll have used aftermarket stuff in my next thread.
Parts for a 99-00 Civic Si:
All parts are brand new,OEM, unopened!:
Water Pump - $79
Oil pump - $78
Timing belt - $47
Valve cover gasket - $7
Intake manifold gasket - $8
Oil pan gasket - $17
Air filter - $12
Oil Filter(2) - $5 /each
Rear main seal - $10
Cam seal - $4
PS belt - $18
AC belt - $7
Alt. Belt - $9
Parts for 96-00 Civic EX:
Alt. Belt - $7
Valve cover gasket - $6
Timing Belt- $25
TB tensioner set - $35
frnt. crank seal - $3
Rear Main - $10
H20 pump - $54
Modified by TRE_ at 1:59 PM 2/22/2006
Modified by TRE_ at 8:03 PM 2/27/2006
Water Pump - $79
Oil pump - $78
Timing belt - $47
Air filter - $12
Cam seal - $4
PS belt - $18
AC belt - $7
Alt. Belt - $9
Alt. Belt - $7
Timing Belt- $25
Rear Main - $10
H20 pump - $54
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _SHEP_ »</TD></TR><TR><TD CLASS="quote">Reliable seller
Bump for Tre</TD></TR></TABLE>
You're such a sweetheart ryan
Found some more stuff in my garage, i'll post it up later after i get a chance to go through all of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBuddy00 »</TD></TR><TR><TD CLASS="quote">ill pry take both the oil and water pump for the Si off your hands. I'll let you know soon. </TD></TR></TABLE>
Sounds good!
Sounds good!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6TURBO »</TD></TR><TR><TD CLASS="quote">might need alot of seals will check back tonight might have to order locally cause my paypal takes too long to clear Need stuff this weekend LOL</TD></TR></TABLE>
PM'd you!
PM'd you!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ »</TD></TR><TR><TD CLASS="quote">Sounds good!
i sent pm
</TD></TR></TABLE>i sent pm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsr2203 »</TD></TR><TR><TD CLASS="quote">i have some all red tails when do you wanna pick them up son</TD></TR></TABLE>
No ****, I need to get those soon man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ »</TD></TR><TR><TD CLASS="quote">alll pms replied to!</TD></TR></TABLE>
