2-way remote start alarm system cheap!
Brand new Spy System remote start system. comes with 2 remotes and window control modules for window roll up/down with a push of a button and you can tell the status of your car by looking at your remote lcd.
Programmable features:
-last door closed automatic arming.
-Ignition key controlled door lock/unlock
-60 second re-arming timer with door re-locking
-Trigger input for all doors, hood, and trunk
-programmable automatic lock
-plug-in multi function alarm status led indicator
-plug-in valet/override toggle switch
-plug-in (-) power door lock output
-plug-in dual stage shock sensor
-Channel 2 & 3 output
-Code hopping transmitters
-Dual mode receiver accepts standard code
-Built-in relay for parking light flash
-Starter kill output
-Panic Feature
-Soft chirp programmable 6-tone siren
-Warn-away feature
-Domelight supervision
It even has a pager system where you walk out the car and if your have kids they can page you with a push of a button to come back to the car and etc. I'm also including the window module to operate two windows to have them roll up and down. This sytem is a great system and it's responder can go up to a mile or so depending on area. So, if Anyone tampers with your car and your alarm goes off...your remotes will go off too. THIS SYSTEM HAS EVERYTHING.
I DO HAVE PICTURES.
-$170.00shipped.
Modified by lilmrchillalot at 1:59 AM 3/2/2006
pic to andyluu811@yahoo.com please thanks
