Please help with my b16 swap. Redline at 7000
Old Feb 22, 2006 | 11:18 AM
Ak_ef9's Avatar
Default Please help with my b16 swap. Redline at 7000
I know something is wrong here. No codes at all. I bought a 98 itr cluster and everything was hooked up correctly. The oil light comes on after high rpms buit not instantly it comes on slightly and then dims out. Also it redlines at 7000 but some times it redlines at 7500. first gen b16 from hmo pr3 ecu
Old Feb 22, 2006 | 11:19 AM
CRXBart's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (Ak_ef9)
sounds like an auto ECU.
Old Feb 22, 2006 | 11:25 AM
Ak_ef9's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (CRXBart)
how can you tell its an auto ecu?
Old Feb 22, 2006 | 11:28 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell its an auto ecu?</TD></TR></TABLE>
it's in the numbers I'm not sure, I'm sure somebody else knows. or you could tear it apart and go to one of the chipping sites and see what the diff is on the board. As for you oil light, I dunno but it doesn't sound good.
Old Feb 22, 2006 | 11:36 AM
Ak_ef9's Avatar
I looked at the ecu and the last numers are 003 which indicates its a 5 spd. Anyhting else it can be?
Old Feb 22, 2006 | 01:52 PM
jacoop86's Avatar
is vtec activating? if not fuel will cut off at 7k rpms. if not then check your wiring. also oil light may indicate that vtec is trying to engage but cant because the engine needs oil pressure to engage vtec. may need new oil pump or may have leek somewhere.
Old Feb 22, 2006 | 02:08 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">I looked at the ecu and the last numers are 003 which indicates its a 5 spd. Anyhting else it can be?</TD></TR></TABLE>
Best way to check is to pull off the 5 screws holding the cover on and look for the A/T or M/T stamp on the circuit board.
Old Feb 22, 2006 | 02:28 PM
Ak_ef9's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (Mr. S)
I am sure that I need a new speed sensor and that will fix the problem
Old Feb 22, 2006 | 03:40 PM
ef2_civic's Avatar
that has nothing to do with it I have no speed sensor and can go to redline stock 8250 on VAFC
Old Feb 22, 2006 | 04:22 PM
SVOboy's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (ef2_civic)
VTEC is dependant on knowing that you're at a certain speed before it can activate, so if your speed sensor doesn't work it could be stopping it from activating (though I dunno about the fuel cut thing).
Old Feb 22, 2006 | 04:28 PM
STREETWERKZ's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">VTEC is dependant on knowing that you're at a certain speed before it can activate, so if your speed sensor doesn't work it could be stopping it from activating (though I dunno about the fuel cut thing).</TD></TR></TABLE>
would also cause a fuel cut too..... car is on some type of limp mode it seems.
could also be LOW OIL. same symtoms with my old B16. changed the oil and filter, went away.... and got vtec back.
Old Feb 22, 2006 | 05:36 PM
snowseeker's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (STREETWERKZ)
Is the motor at operating temps when you are trying this? Should redline at 7 if the motor is cold with no Vtac.
Old Feb 22, 2006 | 06:18 PM
Ak_ef9's Avatar
Default Re: Please help with my b16 swap. Redline at 7000 (snowseeker)
It was up to temp
sisleeper
Apr 13, 2008 11:30 AM
darkshadowcivic
Dec 20, 2004 11:58 AM
chadmasterc
19
Jul 14, 2003 11:08 AM
90civichbsi
20
Oct 8, 2002 10:51 PM
