1998 honda accord V6 problem!!! please help!!!!
Old Feb 22, 2006 | 10:53 AM
1320performancefreak's Avatar
Default 1998 honda accord V6 problem!!! please help!!!!
here's my problem:
the car is 1998 honda accord ex V6 with automatic tranny
well the last few hundred miles i have experience problem with the car after 100-130 miles of local / freeway driving at a stop sign or traffic light while the car is stopped it will just die for no reason. i have changed cap, rotor, ignition coil, ignition control modular, fuel pump spark plugs oxygen sensor and non of them help with the problem there's no check engine light is there any thing else that you guys think might cause the car to die suddenly??? oh and once the car dies u have to wait 2-4 minutes and the car will start again and drive with no problems for another 80-130 miles then the same thing will happen again.
please help!!!!
Old Feb 22, 2006 | 02:23 PM
P_Adams's Avatar
Default Re: 1998 honda accord V6 problem!!! please help!!!! (1320performancefreak)
Main relay or the ECM itself. Also check if your car is involved in a Honda recall for defective Ignition Switches. All three of these will cause your problem.
It sounds like the ECM is loosing power (thus the no lamp issue). Once things cool off, it powers back up and off you got (until it heats up again)
P
Old Feb 22, 2006 | 09:04 PM
any one else?
Old Feb 23, 2006 | 10:52 AM
dodge-honda's Avatar
Default Re: (1320performancefreak)
Does it have a fuel filter? You didn't mention that in the parts you swapped out, it may be getting clogged.
Old Feb 23, 2006 | 12:34 PM
the fuel filter are good for lifetime according to honda.
Old Feb 23, 2006 | 02:29 PM
SuperSlow's Avatar
have your grounds rusted out?
Old Feb 23, 2006 | 04:33 PM
no rust origional CA car
Old Feb 25, 2006 | 07:01 PM
well i think it's the ignition switch even tought the recall is being done on the car already.
Old Feb 25, 2006 | 07:17 PM
YeuEmMaiMai's Avatar
change your relay out.
trwpaper
Mar 20, 2018 08:15 AM
clifftbrd
Jul 11, 2014 01:40 PM
dustinsperling
Mar 25, 2008 09:26 PM
mjacbos
Jul 12, 2007 06:10 PM
radeonboy
Dec 5, 2006 03:06 PM
