Need HELP: Hasport 99-00 civic EK K20 adapter harness EMWK 3 Relay harness wiring
I need some help with this...I am kinda dumb
when it comes to wiring. I bought the harness used from a K20a.org member. The adapter harness has a lot of cut wires / wire ends & I need all the help I can get figuring it out
hasport instructions are here for my particular harness
http://www.hasport.com/Tech/Wring/EMKWH.pdf
I would like to identify what each wire is for & where/how it should be connected
pics
pic 1 -ok
pic2 -ok
pic3 -ok
pic 4 - 3 wires on left????
pic 5 wht/lght blue on left & dark blue on right?????
pic 6 - grey wire????
pic 7 -ok
pic 8 cut wires (same as in pics 9 & 10)
pic 9 (same as in pics 8 & 10)
pic 10 (same as in pics 8 & 9)
pic 11 - wire cut out of red connector
when it comes to wiring. I bought the harness used from a K20a.org member. The adapter harness has a lot of cut wires / wire ends & I need all the help I can get figuring it out hasport instructions are here for my particular harness
pics
pic 1 -ok
pic2 -ok
pic3 -ok
pic 7 -ok
Seems like it is pretty straight forward.. Are you ready to install the harness?
I just read the instructions. believe me,,, it will be so much easier if you waited till you were ready to install it under your dash.....
Also have you contacted the guy you bought the harness from? Maybe he can answer some questions.
I do believe that once installed you will figure it out.
Go here and download the instructions. http://www.hasport.com/Tech/Hasport%20.htm Post any other questions after you have read the instructions.
brian g
brian g
CivicRider011
Audio / Security / Video
Dec 10, 2006 07:07 PM
Cynical 1
Jan 12, 2004 06:17 PM
