i just put a zc in my crx 89 si i have 2 extra wires left help
Old Feb 22, 2006 | 09:34 AM
h22_crx's Avatar
Default i just put a zc in my crx 89 si i have 2 extra wires left help
where do they go?
Old Feb 22, 2006 | 09:59 AM
jdmboxrocket's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (h22_crx)
need a little more info if you want someone to help, bro.
1. what color are the wires
2. location of the wires
3. which zc motor is it?
4. pics would be great
i'll try to help if i can
Old Feb 22, 2006 | 10:01 AM
UltimX's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (jdmboxrocket)
pictures!
Old Feb 22, 2006 | 10:05 AM
h22_crx's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (UltimX)
how do u post a pic
h22_crx's Avatar
the zc is dohc 1.6 non vtec
Old Feb 22, 2006 | 10:08 AM
jlicrx's Avatar
my guess is they went to the Fast Idle Control Valve on the Si - wire colors, blue and black/yellow - not needed on the DOHC ZC
Old Feb 22, 2006 | 10:17 AM
h22_crx's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (jlicrx)
how do u post pics
Old Feb 22, 2006 | 10:28 AM
31flavorscivic's Avatar
im going to guess cylinder position sensor
host the pictures somewhere and put up a link here.
Old Feb 22, 2006 | 10:39 AM
h22_crx's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (31flavorscivic)
http://www.piczo.com/prelude92?g=17533210&cr=1
go down the last pic
Old Feb 22, 2006 | 11:45 AM
UltimX's Avatar
the ringed wire goes on the bolt on the coolant outlet. The other wire i can't tell.
it goes like this, .[img]pic location inthis case, http://pic.piczo.com/img/i165271759_22584.jpg then .[/img]
you have to right click, go to properties, then copy the address.
Old Feb 22, 2006 | 03:13 PM
h22_crx's Avatar
Old Feb 22, 2006 | 03:25 PM
h22_crx's Avatar
i had a post before about how the zc plug would not fit the si .I pop the wires of the zc plug so it would fit the si plug. I have two extra wires left over i think they go to the plug on the pic below. The one wire is blue and the other is blue and yellow.
thank you guys for all your help
Old Feb 22, 2006 | 11:15 PM
Deo's Avatar
Deo
I'm slightly unclear on what's going on (and a little drunk...) but that do-hickey in the last picture is the Cylinder Position Sensor, which is part of the distibutor on the Si. I did a DX to ZC switch with my swap, so I had to run wires from the ECU to that sensor. Not sure how it works on the Si.
Hell, just try running the wires to that sensor, worst that could happen is the motor running like ***.
Edit: It's actually called the Cam Position Sensor on the ZC and I'm begining to think you should just ignore me.
Old Feb 23, 2006 | 02:11 PM
you're right, match them up to that sensor. That's what I had to do.
Old Feb 23, 2006 | 02:27 PM
Groovinator's Avatar
I had one plug left after my install, it looked like a secondary coolant temp sensor, but my si harness didnt have one. so far all i've noticed is that my temp sensor doesnt work when i'm driving, only when i'm in idle. no CEL so its something i cant figure out later.
Old Mar 9, 2006 | 02:39 PM
h22_crx's Avatar
Default Re: i just put a zc in my crx 89 si i have 2 extra wires left help (Deo)
thanks
CRXguy_88
Aug 31, 2010 10:06 PM
90crxdohczc
27
Apr 14, 2006 03:55 PM
h22_crx
Sep 10, 2005 08:51 PM
1990civicsiguye
Aug 18, 2003 10:37 AM
mj
May 31, 2001 10:31 AM
