Suspension & Brakes Theory, alignment, spring rates....
Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si
Old Feb 22, 2006 | 09:24 AM
Design's Avatar
Default **UPDATED** Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si
Have an opportunity to purchase a near-new set of GC coilovers (92-95 civic coupe). Question: Will the coilover sleeves fit over stock shocks on a 99-00 EM1 (Civic Si coupe)? If not, what would I need to make them fit (e.g. new sleeves, etc)?
Here's an application guide for reference. These do fit over Bilsteins:
http://www.nolimitmotorsport.c....html
Sorry for the dumb question. Thanks in advance to anyone that can help.
Modified by Design at 12:41 AM 2/23/2006
Old Feb 22, 2006 | 09:55 AM
AutoXer's Avatar
Default Re: Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si (Design)
From the chart:
MAKE/MODEL.....YEAR.....SHOCK....DROP.......PART #
Civic / Del Sol....92-95....5............0.5 to 4.....4530.03
Shock codes:
1 = Stock
5 = Bilstein
Old Feb 22, 2006 | 01:52 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si (AutoXer)
They're not going to work on your stock shocks if they are made for bilsteins..
Old Feb 22, 2006 | 04:39 PM
Design's Avatar
Default Re: Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si (94eg!)
Thank you.
Old Feb 22, 2006 | 11:40 PM
Design's Avatar
**UPDATE**
Found out they were made for and used on an EG (92-95) with stock shocks. I researched and found inconclusive evidence. Basically, will EG coilovers on OEM shocks fit 99-00 EMI on OEM shocks? I know that GC makes a universal kit for 92-00, but did they ever make an exclusive kit for 92-95 EG's that might use different sleeves?
Thanks again.
Old Feb 23, 2006 | 07:33 AM
94eg!'s Avatar
#1 Super Guy
Loved
They will fit all OEM EK shocks just fine then. The EK's rear lower shock mounting points are slightly different than the EG's, but the part that the coil-over sleeves will sit on is the same.
You should get them...
Old Feb 23, 2006 | 08:13 AM
Design's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">They will fit all OEM EK shocks just fine then. The EK's rear lower shock mounting points are slightly different than the EG's, but the part that the coil-over sleeves will sit on is the same.
You should get them... </TD></TR></TABLE>
Thank you. That also applies to EM1s (99-00 Si)?
Old Feb 23, 2006 | 08:20 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Design &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you. That also applies to EM1s (99-00 Si)?</TD></TR></TABLE>
Yes.
krysted9354
May 19, 2009 01:24 PM
OOOtony
Dec 22, 2006 11:36 AM
Design
Feb 22, 2006 07:15 AM
model x
19
Jan 27, 2003 04:11 PM
amg2k03
Dec 11, 2002 04:11 PM
