Need parts for my swap
Trying to collect the items i need to finish my swap.
This is the list i have so far, please feel free to let me know if i am missing anything.
1. Motor mounts
2. Shift Linkage
3. Traction bar/elimate cross member
4. Water pump
5. Clutch
6. timing belt
7. header
8. intake manfold (skunk2)
9. intake
10. cams
11. cams gears
12. valves and retainers
13. port and polished
14. Not sure what to do on bottom end yet.
15. ECU
16. Dist
17. Blueprint the bottom end
18. Pistons
19. Rods
20. Crank
21. Trans
22. Axles
23. timing belt tensioner
24. rear 91 integra trans bracket
25. new radiator hoses for b series, maybe time for a DA radiator
26. heater hoses
27. fuel lines
28. custom home made bracket for stock throttle cable unless you use integra cable
29. 4 wire trailer wire with waterproof plug for wires to add for vtec ( this wire works great its 4 diff colors together with weatherproof connectors so if you take motor out again you can just unplug like stock wiring harness)
30. header haskets
31. integra cat ( or test pipe)so it bolts up to stock exhaust
32. new O2's
33. oil
34. oil filter
35. fuel filter
36. intake manifold gaskets and throttle body gaskets
37. valve seals
38. valve cover gaskets w/ grommets and plug O rings
39. plugs
40. plug wires
41. cap/ rotor
42. maybe oil pan gasket
43. oil drain plug gasket
44. trans drain plug gasket
45. honda MTF
Thanks.
Modified by teamsonik at 11:36 AM 2/22/2006
Modified by teamsonik at 7:03 AM 2/23/2006
1. Motor mounts
2. Shift Linkage
4. Water pump
5. Clutch
6. timing belt
7. header
9. intake
10. cams
11. cams gears
15. ECU
16. Dist
18. Pistons
19. Rods
20. Crank
21. Trans
22. Axles
26. heater hoses
27. fuel lines
30. header haskets
32. new O2's
33. oil
34. oil filter
35. fuel filter
37. valve seals
39. plugs
40. plug wires
41. cap/ rotor
45. honda MTF
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsonik »</TD></TR><TR><TD CLASS="quote">Trying to collect the items i need to finish my swap.
1. Motor mounts
2. Shift Linkage
4. Water pump
5. Clutch
6. timing belt
7. header
9. intake
10. cams
11. cams gears
Thanks.</TD></TR></TABLE>
Looks good in general but as said above what are you putting in?
1. Motor mounts
2. Shift Linkage
4. Water pump
5. Clutch
6. timing belt
7. header
9. intake
10. cams
11. cams gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsonik »</TD></TR><TR><TD CLASS="quote">what do you mean Blueprint the bottom end? could please explain.
Blue printing is ordering bearings specific to the markings on the rods, caps and the crank.
Such as this on my motor
Cylinder 1 B2, Cyl 2 B2, Cyl 3 B3, Cyl 4 C2
Main 1 4D, Main 2 2B, Main 3 3B, Main 4 2B, Main 5 2B
Taking these number you can order the bearing to blue print the motor. Any good engine builder should do this. Make sure that you use a center punch to mark which rod caps go into each cyl. Just make sure to keep it all in order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Just like, making sure you put the right parts in the right place, a blue print.</TD></TR></TABLE>
Good try.
Modified by CRX Toad at 2:55 PM 2/22/2006
Good try.
Great, thanks for the info. On scale of 1 - 10 on difficulty on rebuilding a honda motor how would you rate this? I think i want to this myself but I am sure going to need some help. I appreciate all the time so far.
I want to do a EF build up thread showing my progress, I think that is kinda kwel.
Hahaha. Woops, I never rebuilt a bottom 100% and I wasn't sure on that. I guess it's another thing learned. It's better then my friend 'B18C5, 1 size fits all' theory. Threw a rod thru his block because he found out that there was different bearings and we had to rebuild his engine on the blown bearings. Oh well. He had money to fix it.
heater hoses
fuel lines
header haskets
new O2's
oil
oil filter
fuel filter
valve seals
plugs
plug wires
cap/ rotor
honda MTF
heater hoses
fuel lines
header haskets
new O2's
oil
oil filter
fuel filter
valve seals
plugs
plug wires
cap/ rotor
honda MTF
smokey.23
Jul 22, 2009 07:40 PM
Kidnkorner
12
Sep 26, 2008 10:33 PM
brian.edge
Feb 20, 2002 12:40 PM
