DA teg rear disc into EF hatch question
Old Feb 22, 2006 | 06:26 AM
typeR_EF_hatch's Avatar
Default DA teg rear disc into EF hatch question
Okay, I just bought a pair of DA rear trailing arms, booster, brake cilinder and distributor from a 91 LS.
I wanted to intall them this weekend but my friend who is a mechanic said i needed a chamber kit cuz the trailing arms did not fit exactly. Is this true?
I did my research and no one says anything about that.
Does anybody know? thanx
Old Feb 22, 2006 | 06:37 AM
HondaFerris's Avatar
Default Re: DA teg rear disc into EF hatch question (typeR_EF_hatch)
they fit fine
Old Feb 22, 2006 | 06:40 AM
CRX Toad's Avatar
tell your mechanic that he should ONLY use the DA trailing arm and that the LCA, UCA, and compensator should be used from the Civic. Also I would encourage you to replace the TA bushings as I am sure they are probably shot.
Old Feb 22, 2006 | 07:06 AM
Default Re: DA teg rear disc into EF hatch question (CRX Toad)
Thanx.
That's what i'd read.
Can you tell me where is the compensator?
Old Feb 22, 2006 | 07:17 AM
CRX Toad's Avatar
The compensator is located at the front of the trailing arm. By the front I mean the part closest to the front end.
DO NOT REMOVE THIS FROM THE CAR JUST THE TRAILING ARM. IF YOU REMOVE IT YOUR ALIGNMENT WILL BE WAY SCREWED UP, INSTEAD OF A LITTLE SCREWED UP.
No matter what you should get an alignment but don't remover that compensator arm from the car.
OnceIwasMuffin
Jun 20, 2018 06:33 AM
Psychoteen101
Oct 27, 2017 03:12 PM
davo91
Apr 30, 2013 09:27 AM
bjorn156
Oct 3, 2004 08:40 PM
Natural Aspirations
Jul 14, 2004 11:46 AM
