1990 Honda Civic Hatchback head problems?
Old Feb 22, 2006 | 05:59 AM
TwiztidNinja's Avatar
Default 1990 Honda Civic Hatchback head problems?
I got a this Honda with 181,000 miles on it. All of a sudden It was idling really rough. I had a friend that's a mechanic, him and I were going thru the car. We found that I had no compression in one cylinder (second away from the distributor) and very little another (closest to the distributor). We checked to make sure the timing belt was lined up, it was. He said that the valves may have burnt out and I need to replace the head. I trust him, but I was wondering if it could also be the head gasket. I'm not getting any abnormal smoke, I have a complete loss of power, and the idle is insanely rough. You can actually hear/feel the firing order. If anyone could give me a hand that would be awesome.
Old Feb 22, 2006 | 06:05 AM
jdm91CrxSi's Avatar
Default Re: 1990 Honda Civic Hatchback head problems? (TwiztidNinja)
my friend is having the same problem we found out his ecu was fried but you need to tell us your eninge im supposing d15
Old Feb 22, 2006 | 07:22 AM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: 1990 Honda Civic Hatchback head problems? (jdm91CrxSi)
the average sign of bad head gasket would be burning oil, burning water, and leakage around the head and block. Where you took out the spark plugs were they clean?
Old Feb 22, 2006 | 10:10 AM
r8r's Avatar
r8r
I'm having the same issue with my d15 only it does blow a little white or white/blueish smoke at first start up and at high rpm's it runs fine. Also on mine my computer says I have a bad fuel injector error code 16. I dunno if that could be the problem or a blown headgasket. I'd like to know some steps to resolution on this as well.
Old Feb 22, 2006 | 10:36 AM
ludesrv's Avatar
Was it an instant lose of power? Or was it over a grace period? If it took a few weeks it's probably a blown valve. At that point it's cheaper to swap the motor then it is to do a valve job. A blow headgasket can be noticed months before it fully fails. My head gasket on my D15B2 was pootched and it still rocked as hard as other D15B2. It would leak oil out of the head and block like crazy tho.
Old Feb 22, 2006 | 12:02 PM
civic16's Avatar
Default Re: (ludesrv)
i had the problem in my civic to. it ended up being a burnt valve so i replaced it and did a touch up to the other valves, it cost me 500 bucks i was pissed, wish i would of just saved up and got a new motor. thats what i am saving for now.
Old Feb 22, 2006 | 01:05 PM
RCautoworks's Avatar
Default Re: (civic16)
Had the same issue with a customers car, compression was
cylinder 1 = 210
cylinder 2 = 5
cylinder 3 = 5
cylinder 4 = 21
found out it was
Old Feb 22, 2006 | 01:10 PM
ck123's Avatar
oil got into the plugs.
my cousin did it for me he replaced..
all 4 cylinders
this huge rubber band thing that went between the valve cover and engine
and the distrubutor
Old Feb 22, 2006 | 02:08 PM
Tippyman's Avatar
Default Re: (ck123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 &raquo;</TD></TR><TR><TD CLASS="quote">this huge rubber band thing that went between the valve cover and engine</TD></TR></TABLE>
lol, the valve cover gasket?
Old Feb 22, 2006 | 06:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">my friend is having the same problem we found out his ecu was fried but you need to tell us your eninge im supposing d15</TD></TR></TABLE>
All right, I have a d15b2. I knew I forgot something when I posted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAS_OCSICNARF &raquo;</TD></TR><TR><TD CLASS="quote">the average sign of bad head gasket would be burning oil, burning water, and leakage around the head and block. Where you took out the spark plugs were they clean?</TD></TR></TABLE>
I do have some oil leak, I am almost positive its coming from the seals on the crankshaft and camshaft pulley. I do go thru oil kinda fast but lately its gotten better. The sparks plugs looked like they were corroted, I but cheap gas... The mechanic I know said thats usually the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Was it an instant lose of power? Or was it over a grace period? If it took a few weeks it's probably a blown valve. At that point it's cheaper to swap the motor then it is to do a valve job. A blow headgasket can be noticed months before it fully fails. My head gasket on my D15B2 was pootched and it still rocked as hard as other D15B2. It would leak oil out of the head and block like crazy tho.</TD></TR></TABLE>
I remember that one morning I fired up the car and it ran insanely rough, I was kinda worried I threw a rod, but I didn't hear any knocking. I checked to see if the timing belt had slipped after I found there was no compression in the 2 cylinders, it was lined up correctly. I did have a problem a month or so before, it was stalling at lights or when I came to a stop (its a manual). So I had to keep the engine revved. I adjusted the idle up a little to solve that cause I didn't have time to worry about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 &raquo;</TD></TR><TR><TD CLASS="quote">oil got into the plugs.
all 4 cylinders
and the distrubutor</TD></TR></TABLE>
I did have to pull the valve cover off to check the timing belt, could it be a multiple problem deal.
THANX FOR EVERYONE'S RESPONSES!!!
Old Feb 22, 2006 | 09:03 PM
ck123's Avatar
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">lol, the valve cover gasket?</TD></TR></TABLE>
umm yeah that thing lol
still in the learning process
Old Feb 23, 2006 | 09:32 AM
Default Re: (ck123)
still in the learning process </TD></TR></TABLE>
That wouldn't cause low compression though.
Old Feb 23, 2006 | 09:48 AM
rbjeepthing's Avatar
Default Re: (90blackcrx)
Blue Smoke = Burning Oil (Normally Valves)
Black Smoke = Burning Gas (Normally Rings)
White Smoke = Coolant (Normally Headgasket)
MengeL
Feb 5, 2016 10:54 AM
Hondapreludeg
Aug 9, 2014 08:29 PM
ej2redcoupe
Apr 8, 2011 02:44 PM
tripwire401
Sep 28, 2010 04:43 PM
kyle h.
Jan 7, 2003 03:50 PM
