Half way thru EF swap. wiring problem
89 Si civic. pulled out the motor yesterday. trying to wire up a non-OBD pr3 ecu while motor is out.
gotta wire up second o2 sensor in pinout C8. accourding to http://www.hasport.com/88-91_Si_SiR_..._convesion.htm, http://b16a.honda-perf.org/wiring.html, and http://tjshondas.20m.com/b16awire.html C8 should be empty. problem is there is a stock wire running to pinout C8 on my car. its grn/wht. now i'm confused and unsure. maybe i'm looking at the wrong pinout. but i looked at 4-5 different times. any got this wire here?
hopefully i can finish the swap and take it to the meet
mine wasnt empty either. i just cut it and connected the O2 sensor there. im not sure where the wire leads though. i havent had any problems so far. good luck
thats really assuring to hear. thanks for replying guys
btw, i was thinking maybe it has to do with my car being made in canada =P
[Modified by Eggman, 4:21 PM 3/28/2002]
btw, i was thinking maybe it has to do with my car being made in canada =P[Modified by Eggman, 4:21 PM 3/28/2002]
C12 and C14 have green/white wires in them. If you are counting correctly you should find a green/white wire in C12 and C14. If not, you are probably orienting the plug wrong.
brian g
brian g
you sure your looking at the plug the right way?, I have both the si and dx 89 wiring diagrham and the only one listed here is a yellow wire and that's only for the automatic equipped civic. make sure your doin it right HTH!!
yup, you guys are right. and i'm glad too. guess i was just tired of wiring up the other stuff or something. thanks.
bmxtrev
Jun 28, 2012 09:17 PM
zx2gotboost
Feb 16, 2006 02:19 PM
