Soft Clutch Pedal
Old Mar 28, 2002 | 10:31 AM
fso_BamBam's Avatar
New User
Default Soft Clutch Pedal
This is been happening gradually, but the pedal has definitely gotten softer. Is this normal wear/tear? What could be causing this? Cause for concern?
Old Mar 28, 2002 | 10:35 AM
MPH's Avatar
MPH
New User
Default Re: Soft Clutch Pedal (fso_BamBam)
Could be air in the lines somehow. Possibly a bad master cylinder. Check the fluid level and bleed the clutch system.
Old Mar 31, 2002 | 01:44 PM
fso_BamBam's Avatar
New User
Default Re: Soft Clutch Pedal (MPH)
Other opinions? Surely, you must have come across this problem at some point. I've never bled a clutch, and I hear it's a major pain in the ***. What else could cause a soft clutch pedal?
Old Mar 31, 2002 | 01:50 PM
TypeR 599's Avatar
have you recently driven a domestic?
Old Mar 31, 2002 | 02:29 PM
MyYellowHonda's Avatar
New User
Actually i find ALL the pedals abit too stiff.. compared with 2 other manul transmission cars that i've ever driven in my life. Friction point is high and the accelerator pedal has to be given alittle bit more push before it'll even budge.. harder for me to feather the pedals with.
Old Apr 1, 2002 | 09:13 AM
SleepyR's Avatar
New User
It just might be in your head. I thought that my clutch was getting soft also. Either that or a stronger left foot.
Old Apr 1, 2002 | 09:52 AM
typer_801's Avatar
You must be joking!!! Probably five minutes of your life at most to bleed your clutch. Much, much easier than bleeding your brakes IMO. Try that first and see if it improves.
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
hannslebo
Mar 24, 2009 01:53 PM
SPOOLINmatt
Mar 14, 2005 01:04 PM
respectblades
Jun 16, 2003 07:28 AM
migs
Nov 28, 2002 07:22 AM
