need a 2.5" carsound cat or any highflow cat
From my page on itr-nc.com about cat/header install:
Should be about $50. Not a bolt-up deal, but install was only $30, which included cutting the first b-pipe restriction out.
Cliff, Chris and I all ordered 2.5" inlet/outlet, 14" long 3-way universal cats from http://www.jegs.com. Order part number
289-15187. If that is not available (it was back-ordered when we needed cats), ask for part number 289-15183. This
one has an air inlet tube that can easily be cut off and welded shut. You will also need an O2 sensor bung, as the
aftermarket cat does not have a fitting for the second O2 sensor. If you order from Jeg's, call 1-800-345-4545 instead
of ordering online - they will know what you need (the website does not have the O2 sensor bung listed).
Another option other than the one Pat mentioned would be to obtain one through "SMSP" on the board
Jason-
who has confidence in Dave
Jason-
Jason-
Jason-
And Dave's solution is bolt-up for ease of install
Drinker
