dude...what the heck is wrong this time.
Old Feb 21, 2006 | 10:41 PM
the soL that could's Avatar
Default dude...what the heck is wrong this time.
94 del sol S (JDM d15b sohc vtec)
soo... i was driving today and something weird happened:
during normal driving. i shifted in into 2nd gear and was at 2k RPMS going to 3k and it lagged... felt like it didn't want to move. i punched the gas and it took a while to respond like an automatic. felt like it choked or i was in 4th gear when i was clearly in 2nd. this engine is bone stock. clutch/flywheel new. transmission has LIFE. engine from hmotorsonline. what could be the problem? o2 sensor? lol no check engine CEL either.
Old Feb 21, 2006 | 10:47 PM
Kevinarich's Avatar
Default Re: dude...what the heck is wrong this time. (the soL that could)
You made sure there was plenty of gas in it right, once this happend to me and it was just because it was low in fuel. Im not saying its something that stupid I just want to remind you that there are times that we forget the most simple things, if it wasnt that, make sure your tps is cool, that will cause hesitation.
Old Feb 21, 2006 | 11:56 PM
x_outlaw_x's Avatar
that hapened to me before and it was a combination of out of gas/distributor
Old Feb 22, 2006 | 06:12 AM
Default Re: (x_outlaw_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">that hapened to me before and it was a combination of out of gas/distributor</TD></TR></TABLE>
i have 1/2 tank of gas and my dizzy is new from the distributor king
Old Feb 22, 2006 | 07:04 AM
Chrisfrom1986's Avatar
are you sure you really didnt go into 4th?
Old Feb 22, 2006 | 07:28 AM
Default Re: (chrisfromda909)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisfromda909 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you really didnt go into 4th?</TD></TR></TABLE>
na man... sometimes it happens in every gear. even when i'm in 4th it should gradually increase in speed. it's not the same lag you experience when you're in a lower gear. it jumps like when you tap on the gas in 1st gear.
Old Feb 22, 2006 | 12:16 PM
anyone?
Old Feb 22, 2006 | 12:26 PM
philosofy1's Avatar
did you changes your fuel filter? what gas are you putting in? maybe fuel pump might be going out, or main relay.
Old Feb 22, 2006 | 12:40 PM
Default Re: dude...what the heck is wrong this time. (philosofy1)
fuel filter is new... main relay is new... fuel pump not changed
Old Feb 22, 2006 | 12:52 PM
aemciv's Avatar
possibly clogged fuel lines.
Old Feb 22, 2006 | 12:55 PM
hmtcrxsir's Avatar
Default Re: (aemciv)
make sure the timing is not off.
Old Feb 22, 2006 | 01:05 PM
Default Re: (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">make sure the timing is not off. </TD></TR></TABLE>
changed my timing before and this hasn't happened until i changed my o2 sensor. but i dout it's that. it's a bosch. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemciv &raquo;</TD></TR><TR><TD CLASS="quote">possibly clogged fuel lines. </TD></TR></TABLE>
how do i unclog?
Old Feb 22, 2006 | 08:02 PM
for the love of ... alcohol... please help me~!
Old Feb 23, 2006 | 06:08 AM
help
Old Feb 23, 2006 | 07:22 AM
snatch's Avatar
I've had this same problem before too. It would usually happen in 2nd as well at around the same RPM, and it would usually be after I let off the gas then pushed it again. There would be a lag, like it was choking.
I never really changed anything, but the problem doesn't seem to be there anymore.
Did it do it just this once or does it always do it?
Old Feb 23, 2006 | 07:33 AM
Default Re: dude...what the heck is wrong this time. (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">I've had this same problem before too. It would usually happen in 2nd as well at around the same RPM, and it would usually be after I let off the gas then pushed it again. There would be a lag, like it was choking.
Did it do it just this once or does it always do it?</TD></TR></TABLE>
yeah... it's pretty much the same ****. it randomly happens for some reason. i've changed my entire distributor, wires, plugs, fuel filter, relay... maybe it's my timing or i need a timing belt change.
it happens like once in a while. not all the time.
Old Feb 23, 2006 | 08:17 AM
LSracing94's Avatar
a shitty O2 sensor could also cause that problem..been there done that lol
Old Feb 23, 2006 | 08:31 AM
Default Re: dude...what the heck is wrong this time. (LSracing94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">a shitty O2 sensor could also cause that problem..been there done that lol</TD></TR></TABLE>
i have a bosch... that's what i'm thinking. everything is freaking new in my car.
Old Feb 23, 2006 | 09:20 AM
ZipTieGUy's Avatar
you acting like bosch is so good. its either your o2 sensor or distributor, most likely distributor
Old Feb 23, 2006 | 09:31 AM
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">you acting like bosch is so good. its either your o2 sensor or distributor, most likely distributor</TD></TR></TABLE>
bosch suks... i know. but it was free.
anyway, my distributor was from the distributor king. imma go check it this weekend.
Old Feb 23, 2006 | 09:35 AM
fit256nj's Avatar
i got a 95 coupe, does the same exact ****, almost seems like its decelerating when your trying to punch it right. I changed the spark plugs and checked the fuel injectors, it didnt help for me but maybe it will help you, also check the timing.
Old Feb 23, 2006 | 09:48 AM
Default Re: (fit256nj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fit256nj &raquo;</TD></TR><TR><TD CLASS="quote">i got a 95 coupe, does the same exact ****, almost seems like its decelerating when your trying to punch it right. I changed the spark plugs and checked the fuel injectors, it didnt help for me but maybe it will help you, also check the timing.</TD></TR></TABLE>
yeah...
here's what i have done.
-Lightweight 7lb Fidanza flywheel/OEM exedy clutch (barely driven)
-NEW NGK plugs, NGK WIRES
-NEW distributor from the distributor king
-P08 ecu included. Virgin/unchipped.
-transmission good ex/si
Old Feb 23, 2006 | 01:52 PM
fit256nj's Avatar
weird man, i dunno maybe the ecu, or the fitv, if the fitv is uncleaned, or clogged could be affecting the idle.
https://honda-tech.com/zerothread?id=699787
that thread shows u how to clean it, really easy, lol and if u already seen it and its not helpful sorry
Old Feb 23, 2006 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fit256nj &raquo;</TD></TR><TR><TD CLASS="quote">weird man, i dunno maybe the ecu, or the fitv, if the fitv is uncleaned, or clogged could be affecting the idle.
that thread shows u how to clean it, really easy, lol and if u already seen it and its not helpful sorry</TD></TR></TABLE>
nothing wrong with my idle. god i wanna shoot myself.
Old Feb 23, 2006 | 02:31 PM
GSaura's Avatar
Default Re: (the soL that could)
I had similar symptoms when my ignition coil went bad. I'd accelerate until it sputtering. Randomly, it would just start right back in accelerating again.
