02' RSX wont start
Old Feb 21, 2006 | 10:36 PM
mr devious illusions's Avatar
Default 02' RSX wont start
this **** is weird. and for some odd reason.. ive got that feeling that i know what ya'll are gonna tell me. but id like to hear what you got to say...
here's the problem...
good battery. everything's checkd out. BUT... car wont start. it'll crank... but it just.. wont start. when i turn the key, all the lights go on... fuses are good... fluids are cool... but again... it wont start...
got any suggestions on what to do?
Old Feb 22, 2006 | 12:31 AM
toomuchrice's Avatar
try a push start then go to the dealer
Old Feb 22, 2006 | 12:07 PM
Default Re: (toomuchrice)
here's what ive tried so far...
- my extra key, since i heard that the one im carring might've been uncoded or whatever...
- checkd out fuses one more time to be sure nothing is blown...
- checkd out the spark plugs. although i dont know where the dizzy n rotor are.. im tryin to find out where that is.. so many i could check that out as well.
those are the steps ive taken so far... =\
Old Feb 22, 2006 | 12:13 PM
f1nal zeros's Avatar
Starter?
Old Feb 22, 2006 | 12:15 PM
Slow EJ8's Avatar
Default Re: 02' RSX wont start (magikalxpinoy)
What method are you using to determine that your battery is dead? You mentioned all the lights working but that does not mean the battery has enough 'umph' to start the car. Try jumping it if you can and that would let you know if it is the battery. Cant hurt anything.
Old Feb 22, 2006 | 12:17 PM
Perfectionist's Avatar
Does the immobilizer 'key' light indicate the correct code is present?
Old Feb 22, 2006 | 02:26 PM
Red CiViC Hatch's Avatar
Default Re: 02' RSX wont start (Perfectionist)
theres no distributor on ur car....did u check to see if there was fuel pressure....i dont see the ignition system f'in up unless the cam or crank sensor went south....
how many miles are on the car?
what modifications do u hav?
Old Feb 22, 2006 | 07:33 PM
proll's Avatar
Default Re: 02' RSX wont start (Red CiViC Hatch)
take the power terminal off the battery for 10 mins..... this happened in my 06...
Old Feb 22, 2006 | 11:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch &raquo;</TD></TR><TR><TD CLASS="quote">theres no distributor on ur car....did u check to see if there was fuel pressure....
what modifications do u hav?</TD></TR></TABLE>
how do i check the fuel pressure?
ive got 50xxx on the motor. i just got the car in october of 2005. the only mod i have on the car is an injen short ram intake. just installed that 2 weeks ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Does the immobilizer 'key' light indicate the correct code is present?</TD></TR></TABLE>
how do i know if it's out? is it that key thing when u turn it off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">What method are you using to determine that your battery is dead? You mentioned all the lights working but that does not mean the battery has enough 'umph' to start the car. </TD></TR></TABLE>
i went to checkers yesterday to get the battery charged. just to check if it holds a charge. and they say it does. i waited a good 30 mins to have it checkd.
Old Feb 23, 2006 | 05:14 AM
deegz's Avatar
?Im still kinda new to rsx's. But I just helped a buddy put a type s together from the junk yard.
I know that we swaped a 02 wiring harness for a 04 and we had these extra plugs and what not. We also used the 04 computer. So we hook everything up and try to start her up. fires but wouldnt start. So we read up on it a little bit. found out that the key has a id registration vin number inside the key and if the computer doest recognize the key, it wont turn on the fuel pump. So try running a relay from your battery to your fuel pump and try to fire it up. If so its a key sitsuation.
So we ended up having to get the other key ignition, and keys
for the 04 comp, luckly they were available
dont know if this will help but just my experience
Old Feb 23, 2006 | 06:40 AM
NBPcivic07's Avatar
check your grounds pehaps
Old Feb 23, 2006 | 08:44 AM
where is the fuel pump located so i can check it out?
Old Feb 23, 2006 | 09:15 AM
mrDFWmechanic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magikalxpinoy &raquo;</TD></TR><TR><TD CLASS="quote">where is the fuel pump located so i can check it out?</TD></TR></TABLE>
in the tank underneath the rear seats
Old Feb 23, 2006 | 12:54 PM
MikeyDB7's Avatar
Default Re: 02' RSX wont start (mrDFWmechanic)
this happend to my sister 02 RSX once..we called Acura Luxury care and they sent a tow truck..
They changed the battery and put in a new starter. 4 years later, havn't had the problem since
Old Feb 23, 2006 | 11:01 PM
Default Re: 02' RSX wont start (MikeyDB7)
im most likely gonna do that too. i got the extended warranty. if anything else goes.. expletive it. imma get me a 06. haha
Old Feb 28, 2006 | 01:07 PM
ck123's Avatar
if its an auto put it in neutral then try again
Old Sep 24, 2023 | 03:12 PM
Cgibso13's Avatar
That key comment thank you! Was having a hell of a time here
97hatch904
Aug 31, 2015 04:38 PM
EjSex
Aug 17, 2007 08:20 PM
andyep3
Jun 1, 2006 06:42 AM
lowblazin
Nov 25, 2003 10:00 AM
low-tech assassin
Honda Motorcycles
Mar 2, 2003 01:02 AM
