Advantages of running open header at the track? Dyno Proof?
Old Mar 28, 2002 | 09:52 AM
SIINSI's Avatar
Default Advantages of running open header at the track? Dyno Proof?
I was at the track yesterday with my friend. He was running an 89 Turbo Trans Am. He ran a 13.2 then opened his dump pipe and ran a 12.9
I am wondering if the open header is what gave him the extra 3 tenths?
What differences have you guys noticed when running open header?
What where your quarter mile gains? Did anyone try it on the dyno?
Just curious....
Miguel
Old Mar 28, 2002 | 10:01 AM
PM-Performance's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (SIINSI)
nope. . . you will get better low end torque, but will lose in top end . i tried it already didt work too good.
Old Mar 28, 2002 | 10:02 AM
unless , , you got a potent *** all motor set up . but im talking real potent
Old Mar 28, 2002 | 10:14 AM
SIINSI's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (itr206)
Interesting, thanks for the info.
A while back I had a DC Race Header. I only had it on for a few minutes....(WAY TO LOUD) I noticed a loss in low end torque but the high end did seem a noticeable difference higher. I guess the trade-off does not help in the 1/4 huh??
Miguel
Old Mar 28, 2002 | 10:56 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
hey migeul, your next dyno tuning session pull the header on your last run. see for yourself if it works. i am curious about this myself.
Old Mar 28, 2002 | 11:02 AM
Chris's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (C5_ALLMOTOR)
I gained about 4 WHP from taking out my testpipe and B pipe completely, right out the header.
The gains were steady from VTEC right up to the top. I also have the JDM 4-1 Header.
This is how I run at the track (I have a straight pipe that dumps right before the gas tank, downward)
Old Mar 28, 2002 | 11:30 AM
SIINSI's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (Chris)
C5.... I hope you're right, I'm gonn give it a try.
rodney... I'm gonna do that... I wanna dyno one more time before I do the work to my motor
Chris 4 WHP is not bad at all. Almost as good as popping of the power steering on some cars I'm gonna have to give it a try.
Thanks fellas.
Miguel
Old Mar 28, 2002 | 11:34 AM
Black R's Avatar
25 Year Member
I gained 3whp just from unbolting and running open header w/ spec b's - went from 185-188whp and gained 2-3wtq too... On the dyno.
Old Mar 28, 2002 | 11:43 AM
B18CXr's Avatar
If you have a "proper" cat back, you will see minimal gains by running open header.
Old Mar 28, 2002 | 11:49 AM
Chris's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (B18CXr)
Yea. But most do not! I was refering to the Stock B pipe in my post.
Old Mar 28, 2002 | 11:50 AM
B18CXr's Avatar
true,true
Old Mar 28, 2002 | 12:34 PM
Racer-X's Avatar
I don't know most tracks won't let you drive with open header due to noise violations. I believe ours is 112dB and I've heard some loud as 120+ and there normally told they can not drive unless they put a muffler on that car.
Old Mar 28, 2002 | 12:49 PM
SIINSI's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (Racer-X)
At Raceway Park in Englishtown, NJ you can run UN-Muffled on Wednesdays.
Miguel
Old Mar 28, 2002 | 12:56 PM
Black R's Avatar
25 Year Member
Ditto. My gains were from open header vs. stock catback.
Old Mar 28, 2002 | 01:18 PM
SIINSI's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (Black R)
So then there really wouldn't be too much of a gain over a 2 1/2" exhaust with no cat and a E-S Muffler? What the hell, I'll give it a try anyway. It's easy enough to do
Miguel
Old Mar 28, 2002 | 09:16 PM
scooter's Avatar
Hey Miguel, when I got your DC header I put it on and my car ran super lean. That is almost open header, I dont know if something was wrong with my car but when we modified the header to fit the exhaust it was still a little lean but it was much better than with no exhaust (I have mugen exhaust). I dont know if I would run the snot outa the motor if there was a chance it would run super lean up top, especially with big cams like you have. you may wanna run it on the dyno open header first.
scott
Old Mar 28, 2002 | 09:35 PM
mingchi96
Guest
Posts: n/a
Default Re: Advantages of running open header at the track? Dyno Proof? (scooter)
On the dyno.. i dynoed 225 with an open header (SAE corrected) and i dynoed 219 with a full exhaust (2.375" only) so thats a gain of roughly 6 hp. on the dyno comparison of the two, the low end were exactly the same up to roughly 6500 rpms.. where vtec (top end) is fatter, better top end. I dunno what you guys consider a bad *** NA motor, but my dyno is below.
Old Mar 28, 2002 | 09:46 PM
Chris's Avatar
Most tracks out here are out in the middle of the desert. or no-where.. no limits (none that I have been told of) except Laguna Seca..89dB
Old Mar 29, 2002 | 04:40 AM
Rodney's Avatar
.rodney... I'm gonna do that... I wanna dyno one more time before I do the work to my motor
well, lemme know if you want to go to the place upstate. they have night appointments, so i could meet up with you. give me a call when you want to go.
Old Mar 29, 2002 | 05:12 AM
Evil DOHC's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (rodney)
Hey SIINSI, Did you buy that car from one of the guys from JDM Hondaparts and had it shipped to ny? I met you at dunkin donuts in union one day. Also saw you at the track. The 1/4 mile times definatly improved since the last time I saw the car run. Good Job man, shoot me an im sometime, when you are goin to the track.
EVIL
Old Mar 29, 2002 | 05:20 AM
Mike K's Avatar
Default Re: Advantages of running open header at the track? Dyno Proof? (Evil GS-R)
I saw little to no gain at all on my B20/B17...
but then again I have SMSP quality from the header to the rear bumper all the way through!
Old Mar 29, 2002 | 05:32 AM
Default Re: Advantages of running open header at the track? Dyno Proof? (Mike K)
i actually lost time at the track . i unbolted the b pipe and hung it to the side. i lost top end . just didnt feel right, that s was with the stock header though.
i was looking for any kind of free hp i could get and that wasnt there for me .
at english town , they dont give a **** , they say they do , but thats where i ran it and all the rotaries and **** there are no where even close to muffled. but my car sounded like one of the rotaries it was funny.
Old Mar 29, 2002 | 06:34 AM
oz#227's Avatar
New User
Agreed, it depends on your setup.....but remember these 3 tenths were on a FI car. They aren't as fussy about back-pressure. Our NA cars is.....
Just my 2c.
Later.
Old Mar 29, 2002 | 07:24 AM
Default Re: Advantages of running open header at the track? Dyno Proof? (oz#227)
well im gonna try it with the nitrous this year to see if that makes a diff. . .im always down to try . ill let you know . i got an even t in a couple weeks
Old Mar 29, 2002 | 07:43 AM
Michael Delaney's Avatar
Skunk2's Steve Rothenbuehler's B20VTEC with Greddy catback on
and with it off:
