b16a head gasket... OEM or SPOON?
Old Feb 21, 2006 | 07:57 PM
Master23's Avatar
Default b16a head gasket... OEM or SPOON?
My set up is B16a with CTR piston. I've been searching about the headgasket and i can't get a straight answer. I want to raise the compression a little bit higher so should i go with a spoon head gasket or OEM gasket and remove one layer? Removing one laying of OEM head gasket... is that safe?
Old Feb 21, 2006 | 08:11 PM
PphamEK's Avatar
Default Re: b16a head gasket... OEM or SPOON? (Master23)
Y would u wanna remove one layer for, if any thing u stack them. u should get inline pro head gasket , there good
Old Feb 22, 2006 | 10:07 AM
Master23's Avatar
Default Re: b16a head gasket... OEM or SPOON? (MugenedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenedEK &raquo;</TD></TR><TR><TD CLASS="quote">Y would u wanna remove one layer for, if any thing u stack them. u should get inline pro head gasket , there good</TD></TR></TABLE>
The post is about OEM head gasket being safe with only two layer or Spoon head gasket, not inline pro. You didn't even state if inline pro head gasket would raise my compression. Anyone else who knows more about this?
Old Feb 22, 2006 | 12:46 PM
NineTwoSi's Avatar
Thinner head gasket = higher compression (that's why)
Old Feb 22, 2006 | 12:49 PM
. a d a m's Avatar
I wouldn't want to tamper with removing layers of the oem headgasket. If you want higher compression dish out the cash for a Spoon headgasket or something similar.
just my .02
Old Feb 22, 2006 | 12:56 PM
Padawan's Avatar
Darth ModerVader
Many people modify an OEM gasket and don't experience any problems. However, I always suggest an actual 2-layer gasket such as the one offered by Mugen. It isn't all that much more expensive than an OEM gasket, and it was designed specifically to function correctly as a 2-layer piece. In all likelihood, you won't have any issues regardless of which option you select, but since pulling a head isn't a terribly quick job, I just prefer to go with the Mugen gasket for additional peace of mind.
Old Feb 22, 2006 | 01:01 PM
EX-T's Avatar
Just take your head off, get it milled, and put it back on with an OEM gasket!
Old Feb 22, 2006 | 01:26 PM
chilly.'s Avatar
mugen head gasket raises compression by .04
Old Feb 22, 2006 | 01:30 PM
6SPD_EK's Avatar
Default Re: (J-TIZZ)
for those that don't know...spoon's 2-layer B-series gasket IS an OEM honda B-series without the middle layer
mugen's was specifically designed to be 2-layer..... which is why I am getting mugen's gasket for K20a
Old Feb 22, 2006 | 01:34 PM
Nevaeh Speed's Avatar
mugen... I had that on my b16 with ctr pistons.... good little setup
Old Feb 22, 2006 | 01:35 PM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-TIZZ &raquo;</TD></TR><TR><TD CLASS="quote">mugen head gasket raises compression by .04 </TD></TR></TABLE>
you mean .4 lol
Old Feb 22, 2006 | 01:39 PM
chilly.'s Avatar
my bad
fmrprojects's Avatar
Default Re: b16a head gasket... OEM or SPOON? (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">Just take your head off, get it milled, and put it back on with an OEM gasket!
what he said
Old Feb 22, 2006 | 01:50 PM
Padawan's Avatar
Darth ModerVader
Default Re: (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">
you mean .4 lol </TD></TR></TABLE>
Indeed, and in fact, all the information I've seen indicates that the gain is actually closer to +0.3:1 for the Mugen gasket.
Old Feb 22, 2006 | 01:56 PM
6SPD_EK's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Indeed, and in fact, all the information I've seen indicates that the gain is actually closer to +0.3:1 for the Mugen gasket. </TD></TR></TABLE>
i stand corrected didn't know that....still learning something here....everyday
Old Feb 22, 2006 | 02:07 PM
Padawan's Avatar
Darth ModerVader
i stand corrected didn't know that....still learning something here....everyday </TD></TR></TABLE>
The information you provided is what Mugen itself claims, so you can't be faulted for that. The 0.3:1 number is something that has been suggested by several individuals here on H-T, though I have not seen any 100% concrete evidence to support either figure. Of course, the difference is small, so it is basically a moot point either way.
Old Feb 22, 2006 | 02:18 PM
EcstasyofGold's Avatar
Im runnin' a 92cx hatch, b16 with CTR pistons and a mugen head gasket... runs great. People claimed the compression would be "a little high for street driving" but I don't mind it at all. It's been almost 10k mi. since the build and it's still running strong.
Old Feb 22, 2006 | 02:26 PM
Kevinarich's Avatar
A little off the topic does anyone know how high of compression you can go without detonation using 91 octane?
Old Feb 22, 2006 | 03:18 PM
Sliced Beard's Avatar
Default Re: (Kevinarich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote"> since pulling a head isn't a terribly quick job</TD></TR></TABLE>
what are you talking about......I can replace the head gasket on a D in less than 40 minutes and I can replace a head gasket on a B in less than 50-60 minutes.
it is extremely simple mang
Old Feb 22, 2006 | 03:27 PM
Master23's Avatar
Thanks for all the response. I looked up the spoon and mugen gasket on inlinefour.com. Compared to each other, the Spoon measured to .45mm and the mugen gasket measured .47. So im guessing if i want more compression, i'll go with the Spoon .45mm. Thanks for all the replys!
Old Feb 22, 2006 | 03:41 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the response. I looked up the spoon and mugen gasket on inlinefour.com. Compared to each other, the Spoon measured to .45mm and the mugen gasket measured .47. So im guessing if i want more compression, i'll go with the Spoon .45mm. Thanks for all the replys! </TD></TR></TABLE>
The difference is nominal, but I prefer the Mugen gasket because it seems to have been used by the most people with the greatest success, and as mentioned above, it is a purpose made 2-layer gasket.
Old Feb 23, 2006 | 03:33 AM
6SPD_EK's Avatar
SPOON = more compression yes? less reliability - most likely than Mugen
CRXsmoke
Mar 21, 2006 10:34 AM
OldSkoolDA
Sep 25, 2005 02:26 PM
HondaGuy02
Jul 9, 2004 04:49 PM
rough_draft
May 5, 2004 12:53 AM
