SOHC ZC Swap on the way. Got a few Issues to work out!
Old Feb 21, 2006 | 07:37 PM
Tippyman's Avatar
Default SOHC ZC Swap on the way. Got a few Issues to work out!
Well, my car died and it's gonna be way to much to fix it. Screw it, I said, I'm getting an SOHC ZC.
So...
When I buy parts for this motor (Ex. Header, IM, replacement parts, etc.) what do I buy them for? I heard that the ZC was identical to another motor? What is this motor?
Also, I have an Std. civic which was plagued with the 4 speed manual tranny. If i buy a ZC tranny off of H-motors can i just bolt it in or do i have to get new axles as well?
Old Feb 21, 2006 | 07:39 PM
Tippyman's Avatar
Default Re: SOHC ZC Swap on the way. Got a few Issues to work out! (Tippyman98)
This is the tranny BTW: http://www.hmotorsonline.com/s...40007
Old Feb 21, 2006 | 07:53 PM
evil_ryu's Avatar
i believe its a replacement for the D16a6 but correct me if im wrong... ive got a 91 civic with a ZC SOHC and right now and im replacing the head gasket.... everything i ordered was for the 1.6 motor...
Old Feb 21, 2006 | 08:00 PM
Tippyman's Avatar
Default Re: (evil_ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil_ryu &raquo;</TD></TR><TR><TD CLASS="quote">everything i ordered was for the 1.6 motor... </TD></TR></TABLE>
Which 1.6 motor? i know the ZC is a 1.6 L but which 1.6 L?
Old Feb 21, 2006 | 08:02 PM
Groovinator's Avatar
Default Re: (Tippyman98)
a d16a6 motor is the one it crosses over with here.
if you need parts jsut tell the parts guys you have a 88-91 Si motor. (easiest way to explain it)
Old Feb 21, 2006 | 08:17 PM
Tippyman's Avatar
cool beans. Now... what about that tranny question?
Old Feb 21, 2006 | 09:01 PM
good question. if no one answers before i get to work tomorrow, i'll check hondacom for yah
Old Feb 22, 2006 | 03:08 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">Also, I have an Std. civic which was plagued with the 4 speed manual tranny. If i buy a ZC tranny off of H-motors can i just bolt it in or do i have to get new axles as well?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">This is the tranny BTW: http://www.hmotorsonline.com/s...40007</TD></TR></TABLE>
Anyone?
Old Feb 22, 2006 | 05:41 AM
jdm91CrxSi's Avatar
bump ... put it simple.. most d code motors will fit anything on another d code ya.. mean
Old Feb 22, 2006 | 07:01 AM
HumanResource's Avatar
you need equal length axles like 90-93 Integra units to match up the ZC trans with big diff.
If you're lucky you might end up with the 4.437 FD tranny
Old Feb 22, 2006 | 07:41 AM
ludesrv's Avatar
Get a D16A6 tranny and use the stock axles. You will love the shorter gears as much as I do. Alot peppier then the long ZC ones. You need to use the SOHC ZC half shaft and the SOHC ZC axles. Or you can youse 88-89 Teg axles and half shaft. I suggest you use the stock axles with the regular D16A6 tranny. Easier to find, cheaper to replace.
Old Feb 22, 2006 | 07:55 AM
D95si420's Avatar
Default Re: (ludesrv)
if it were me i would try to find a SI trans. ZC trans is geared pretty good but not as short as SI. Alot of people make a hybrid trans with ZC and SI gear combo's and final drive. Some of the DOHC ZC's came with LSD too but use a halfshaft, and if u dont get it with the trans its pain to find or mod a usdm one to fit anyway there are many threads to see if the trans u have is LSD. One of my boys in VA a while back bought a ZC swap from noyan and decided to use his SI trans with it. he did not know much about the ZC trannies so he offered it to me for free just for helping him do a MPFI swap I was never so happy to look through the diff and see no pin in the middle and daylight, LSD baby!!!! It WAS a option on the DOHC trannies so make sure u check casue u never know what u may get. there was alot of conflict on here at one point as to what intermediate shaft u could use with it and what axles but thanks to helpful people its sorted out with a nice writeup now. Anything would be better than the 4 speed even a dx 5 speed. check around on the classifieds and your local junkyards, u may be able to score a SI trans cheaper than u think, either way it will bot up to the zc just like any d-series. Make sure to get a 88-89 if u have that year or 90-91 casue clutch size is diff and flywheel too. hope i was able to help some bro, sory about the long post
Old Feb 22, 2006 | 08:07 AM
crx_88_si's Avatar
SOHC ZC tranny = same as D16a6 Tranny.
DOHC ZC Tranny = equal length axles.
bolt your Std axles to the SOHC Zc tranny and be done with it.
Old Feb 22, 2006 | 01:57 PM
Tippyman's Avatar
Default Re: (crx_88_si)
cool. thanx, thats wut i wanted to do.
B18C1_CRX
Oct 7, 2006 09:43 AM
crex23
18
Mar 30, 2005 05:03 AM
zeptozorro
Jan 18, 2004 09:01 PM
CRneXt
39
Oct 7, 2003 02:13 PM
