Idle Wandering
Old Feb 21, 2006 | 07:37 PM
Jesterian's Avatar
Default Idle Wandering
This just recently started: when I idle, the rpms wander around on me. What could this be?
Old Feb 21, 2006 | 07:39 PM
Ak_ef9's Avatar
Default Re: Idle Wandering (Jesterian)
wander as in how? Like it goes up and down or like it idles at 200 rpm
Old Feb 21, 2006 | 07:46 PM
ghost_ryder35's Avatar
Default Re: Idle Wandering (Ak_ef9)
do they go to the left and then to the right or do they just run around you in circles? Most likley a vaccum leak.
Old Feb 21, 2006 | 09:57 PM
Jesterian's Avatar
Default Re: Idle Wandering (ghost_ryder35)
It goes up and down, sometimes chills around 2k then drops down to like 600, goes back up to 1.5k, etc.
Old Feb 21, 2006 | 10:24 PM
Ak_ef9's Avatar
if I am not mistaken that is you sensor that is the back of the intake mianifod. Also what it might be is if you dont have enough coolant then it will run like that too
Old Feb 21, 2006 | 11:24 PM
ED7's Avatar
ED7
Most likely a vacuum leak. The iacv is trying to bring the idle down, but there is too much air entering. So then you get the surging. Check all vacuum hoses and also check where the intake mani connects to the head for any leaks.
Old Feb 22, 2006 | 10:37 AM
Jesterian's Avatar
Default Re: Idle Wandering (ED7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">if I am not mistaken that is you sensor that is the back of the intake mianifod. Also what it might be is if you dont have enough coolant then it will run like that too</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED7 &raquo;</TD></TR><TR><TD CLASS="quote">Most likely a vacuum leak. The iacv is trying to bring the idle down, but there is too much air entering. So then you get the surging. Check all vacuum hoses and also check where the intake mani connects to the head for any leaks.</TD></TR></TABLE>
Which of these is more likely?
Old Feb 22, 2006 | 10:58 AM
efyou's Avatar
i dunno im having the same problem as well so i wanna know, my head gaskets blown tho lol
Old Feb 22, 2006 | 11:34 AM
dandizel's Avatar
Default Re: Idle Wandering (efyou)
Vacuum Leak
Old Feb 22, 2006 | 11:39 AM
Ak_ef9's Avatar
Default Re: Idle Wandering (dandizel)
start the engine and listen for a hissing sound. check your coolant easy to do both at the same time
Old Feb 22, 2006 | 11:51 AM
Slacker87's Avatar
I just fixed this problem on mine after a lot of research. It could be Idle air control valve, Fast idle thermo valve, vacume leak, Ecu problem, Idle control screw on throttle body, Throttle body positioning sensor, Bad coolent or not enough coolent, thermostat.
As you can see too many things can cause this problem check to see if your throwing any codes. Hopes this helps
Old Feb 22, 2006 | 11:56 AM
65stang90crx's Avatar
Default Re: Idle Wandering (hCrx90)
It could be the O2 sensor, sometimes it will cause the idle to go up and down if its bad.
rsa0905
Feb 27, 2010 07:01 AM
Force1stiptopped
Mar 24, 2008 04:17 PM
poormans_typer69
Oct 30, 2007 05:10 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
virusiidx
Jan 18, 2005 07:21 AM
