B18b in a 96 hatch
Hi, im am about to drop a b18b into my 96 hatch. i was wonderin if i would have to do anything else to make the car run. i know u have to have a conversionharness for obd2 to obd1 cuz the motor is obd1. would stock motor mounts fit still? what are good motor mounts fot the car(i heard avid is not bad) As far as transmission goes if i get a cable tranny what will i exactly have to do(i herd u have to take out your whole dash just to run the cable and i herd u can just run the cable with out takin the dash out and cuttin a hole inthe fire wall to run it. Could i still keep my A/C? Tx
you need to get 99 or 00 si mounts for your need tranny , rear , upper left and the mount that goes on the block for upper left an both front torque mounts, an dont get a cable tranny you can also use your stock harness to wire its not hard at all
i can use my stock harrness even though mine is obd2 and im probly gettin a obd1 motor, wont i read check engin light and wont i have to change my distrubutor?
Modified by MugenedEK at 9:36 PM 2/21/2006
Originally Posted by you also can get mounts from an integra if they are in good shape [img
https://honda-tech.com/forums/images/smilies/emsmile.gif[/img]
i have a 98 coupe with b18b used stock ex wire harness every thing will plug in then get a jumper harness to ob1 to run p75 an she will run great
blaak-crx
Apr 23, 2008 09:02 PM
eglslsd
May 30, 2007 05:12 PM
