if a cars alignment is really off would it try to pull off the dyno?
Old Feb 21, 2006 | 06:19 PM
B18ceed's Avatar
Default if a cars alignment is really off would it try to pull off the dyno?
i was havin my car dynoed the other day and the guy at the shop had to really hold on tight to keep it on the dyno? tie downs were tight, everything was as it should be.
Old Feb 21, 2006 | 06:21 PM
SlamminS85's Avatar
Default Re: if a cars alignment is really off would it try to pull off the dyno? (B18ceed)
if the wheels are not straight, yes
Old Feb 21, 2006 | 06:22 PM
Reid's Avatar
Global Moderator
Alignment should not matter, as cars will center themselves on the rollers. I've dynoed cars with bad alignments.
If the car came close to falling off the rollers, it was not centered and strapped down properly.
Old Feb 21, 2006 | 06:25 PM
SlamminS85's Avatar
Default Re: if a cars alignment is really off would it try to pull off the dyno? (Reid)
if the allignment is off... and i mean REALLY off so that one wheel is at an angle when the otehr is straight, the car will not naturally center and try to drive off the drum... but if you cars allignment was that bad then you would have noticed driving over
Old Feb 21, 2006 | 06:46 PM
B18ceed's Avatar
Default Re: if a cars alignment is really off would it try to pull off the dyno? (SlamminS85)
i can drive the car 65 and take my hands off the wheel and it goes straight no problem. the car was alittle off when they pulled it on but did straighten out?i dont have power steering would that matter
Old Feb 21, 2006 | 06:50 PM
SlamminS85's Avatar
no, power steering only would have an effect from the drivers perspective
Dezso3
Honda Civic (2006 - 2015)
Jan 24, 2015 12:51 PM
aLTLuda
Jul 21, 2004 02:53 PM
