difference between 90-93 and 94+ Integra LS axles?
Hey.. I have a crx with a gsr, and im going to pick up some stage 2 gators to replace my worn axles.. (want something that with hold with some hook)
Anyways.. Since i didnt do the swap (bought the car with it) Im unsure which axles i actually have.
I laid a pair of 98 gsr axles beside mine (for my friends swap) and both of mine appear to be a a bit longer..
Are 90-93 LS axles longer then 94+'s?
Would pics help?
Just want to make sure i order the right stuff here. Thanks alot.
Would pics help?
Its the transmission or Intermediate shaft you are using that will determine which axles to use, not the engine.
If you are running a 90-93 Integra Intermediate shaft, you need to get the matching Drivers side axle.
If you are running a 94+ Hydro Intermediate shaft, you will need to get the matching Driver's side axle with a FEMALE end.
The information you have provided is too incomplete to determine what axles you should get.
The drivers side axles for 90-93 and 94+ are completely different.
If the intermediate shaft has a female end (axle side), it's a 90-93 teg axle. If it has a male end (axle side), it's a 94-01 teg axle.
pass side axle is all the same 90 up, only difference is abs or not, as stated before driver side is dictated by what intermediate shaft you have
Well, assuming you are running a CABLE tranny, you are most likely using a 90-93 shaft, unless you changed out the Driver's side axle seal on your tranny to use a 94+ shaft.
The 90-93 shaft has a male end into the tranny, a female end for the axle.
The 94+ shaft has a male on both ends for the tranny and axle. The axle will have a FEMALE end.
lilpastrana
Sep 6, 2007 07:30 AM
NIKE23USC
Aug 6, 2003 05:07 AM
