DAs what header are you guys running?
Old Feb 21, 2006 | 05:55 PM
VtecDA9's Avatar
Default DAs what header are you guys running?
What headers are you guys running in your DAs?
I'm looking to get a better header than my DC 4-2-1. The motor is a high compression ls/vtec that is going to be running BC3+ cams.
Thanks
Old Feb 21, 2006 | 05:56 PM
scheistermeister's Avatar
Default Re: DAs what header are you guys running? (VtecDA9)
stock until i get a turbo manifold
Old Feb 21, 2006 | 06:03 PM
SlamminS85's Avatar
Default Re: DAs what header are you guys running? (scheistermeister)
stock untill i turbo
Old Feb 21, 2006 | 06:39 PM
92DAIntegraXSI's Avatar
DC 4-2-1 untill i finsh my lsvtec build then 4-1 dc or comptech
Old Feb 21, 2006 | 06:43 PM
watsvtecEK's Avatar
Default Re: DAs what header are you guys running? (92DAIntegraXSI)
pacesetter 4-2-1 , not as bad as everyone says though.
Old Feb 21, 2006 | 06:57 PM
riceball777's Avatar
i'm running the oem jdm itr 4-1 with 2.5 collector
any 4-1 header youwill have to notch the crossmember.
2 piece headers are easy to install
and 4-1 or 4-2-1 that not 2 pieces will be a bitch to install and will require you to take off the crossmember
lewylou
Jan 21, 2003 05:43 AM
ic108
Jul 9, 2002 04:42 AM
acteg94
Jun 4, 2002 10:27 AM
rudeS2k
Oct 1, 2001 02:13 PM
