White Smoke
Old Feb 21, 2006 | 05:52 PM
mcgee*'s Avatar
Cigarette Squad
Default White Smoke
Just replaced head because i had black smoke and spitting oil out of it, now its just smoking white(smokes after 4k rpm).. only been 3 days should i wait?,also should i change the oil and use that **** that cleans the block to help it
Old Feb 21, 2006 | 06:16 PM
john666's Avatar
Default Re: White Smoke (McGeeTM)
how much miles have you put on it..
Old Feb 21, 2006 | 06:19 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: White Smoke (john666)
108
Old Feb 21, 2006 | 06:29 PM
SixguN's Avatar
Did you replace headgasket, clean surface's really good?
Edit: worded something wrong.
Modified by Sixgundone at 9:09 PM 2/21/2006
Old Feb 21, 2006 | 06:45 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: White Smoke (Sixgundone)
yup, real clean
Old Feb 21, 2006 | 06:58 PM
EX-T's Avatar
White smoke = coolant!!!!!
Old Feb 21, 2006 | 07:21 PM
.Ry's Avatar
.Ry
Default Re: White Smoke (DSeriesBKilla)
Everytime you start it or when its cold? White smoke when cold is normal. Other than that check for a headgasket leak. Pop off your radiator cap, oil cap. You know what to look for.
Old Feb 21, 2006 | 07:47 PM
PphamEK's Avatar
white smoke ussaly mean its ur head gasket. did u torque it to the right specs?
Old Feb 21, 2006 | 08:10 PM
SixguN's Avatar
Default Re: White Smoke (MugenedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenedEK &raquo;</TD></TR><TR><TD CLASS="quote">white smoke ussaly mean its ur head gasket. did u torque it to the right specs?</TD></TR></TABLE>
Can't you put a headhasket on backwards and have this same effect? Not guessing, I wanted to know actually.
Old Feb 22, 2006 | 05:43 AM
mcgee*'s Avatar
Cigarette Squad
yeah, well this morning i let it warm up and everything and then doged it down the road no smoke.
so im thinkin the weather was the reason
Old Feb 22, 2006 | 05:44 AM
mcgee*'s Avatar
Cigarette Squad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote">
Can't you put a headhasket on backwards and have this same effect? Not guessing, I wanted to know actually.</TD></TR></TABLE>
yeah but ull be able to tell cause certain holes wouldnt line up.
Old Feb 22, 2006 | 07:36 AM
DAxsi16's Avatar
9hatch6
Aug 5, 2007 06:29 PM
ELSUICIDA
13
Apr 4, 2007 06:07 PM
gmboogy
Nov 29, 2006 01:44 AM
Civic Hx-T
13
Apr 14, 2005 05:15 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
