SOHC ZC fuel pressure????
Old Feb 21, 2006 | 05:35 PM
migizzel's Avatar
Default SOHC ZC fuel pressure????
Does anybody know how much pressure should i be running in this engine i have an IM, AEM fuel rail, B&M regulator and gauge, stage 1 excedy clutch, Megan racing headder and thermal exhaust.
im currently running at 28psi
Old Feb 21, 2006 | 05:51 PM
xaine's Avatar
Default Re: SOHC ZC fuel pressure???? (migizzel)
my d16a6 runs 30-31 at idle
if i bump it up to 32-33 at idle it really gets fast
but black smoke comes from running too rich so
i would suggest you turn it up a little
Old Feb 21, 2006 | 06:04 PM
migizzel's Avatar
Default Re: SOHC ZC fuel pressure???? (xaine)
so if i put it at 31psi ill be safe?
Old Feb 22, 2006 | 11:56 AM
xaine's Avatar
I really dont know for the zc
but for the si the manuel says:
with the vaccum hose disconected form the fuel pressure regulator
84-90 fuel injected 35-41 psi
91 fuel injected 40-50 psi
dont know why its says it like that
but mine is at about 40 with the vaccum disconected
my stock Fpr was at 38
Hope that helps you
boostedteg15
Jul 31, 2006 11:40 PM
spdracer89si
Mar 22, 2004 07:36 AM
sloweh3
Feb 8, 2004 01:13 AM
