Need Help! New cams, car wont move?!?
Old Feb 21, 2006 | 04:52 PM
handa's Avatar
Default Need Help! New cams, car wont move?!?
I had Skunk 2 Stage 2 cams in my car, then i took em out to sell them. I just got done putting in my old CTR cams back in. Now when the car is started,it doesnt wanna rev.It wont even rev past 3k. I havent had time to adjust my valves because it got dark outside, could that be the problem???
Old Feb 21, 2006 | 04:56 PM
Bradstard's Avatar
Default Re: Need Help! New cams, car wont move?!? (handa)
Sounds like your timing belt is off a tooth or so on your cams. Put the crank to TDC and check your cam gears.
Old Feb 21, 2006 | 05:02 PM
handa's Avatar
Default Re: Need Help! New cams, car wont move?!? (Bradstard)
when i did timing, i double checked the gears and and the crank pulley. Everything was straight, I could double check it but do u think not adjusting the valves at all would make that problem, i didnt have time to adjust the valves.
Old Feb 21, 2006 | 05:25 PM
D's Avatar
D
TPS and MAP sensors connectors switched?
Modified by D at 10:20 PM 2/21/2006
Old Feb 21, 2006 | 05:50 PM
Haleiwa-Brando's Avatar
Default Re: Need Help! New cams, car wont move?!? (D)
Out of curiousity, why would you do half a job then start your car up and expect it to run properly?
Old Feb 21, 2006 | 08:16 PM
handa's Avatar
Default Re: Need Help! New cams, car wont move?!? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Out of curiousity, why would you do half a job then start your car up and expect it to run properly?</TD></TR></TABLE>
I stated it got dark and I do not have a garage at the moment, so...... anymore suggestions??? thanks for the replys
Old Feb 21, 2006 | 08:27 PM
43MA's Avatar
did you turn the crank 2 turns and double check the marks?
do the valve adjustment then start the car
Old Feb 21, 2006 | 08:38 PM
handa's Avatar
Default Re: Need Help! New cams, car wont move?!? (43MA)
no i didnt double check the marks, tomorrow ill look over everything again and try to give it a valve adjustment, will let you guys know wassup.
Old Feb 21, 2006 | 08:40 PM
dnasol's Avatar
I had a friend with the same problem. His valves weren't adjusted correctly. Good luck.
Old Feb 21, 2006 | 09:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt double check the marks, tomorrow ill look over everything again and try to give it a valve adjustment, will let you guys know wassup.</TD></TR></TABLE>
I'm not meaning to come across as a dick. I'm just trying to figure out your logic. If you had planned on checking everything in the morning (when you had enough light to do so), I just don't understand why you would start the car knowing you would be adjusting the valves and everything.
I hope that you didn't damage anything. Did you double check your torque specs while installing the cams? Are you using stock cam gears or aftermarket? If aftermarket, did the cam gears slip a few degrees?
Old Feb 21, 2006 | 10:54 PM
43MA's Avatar
torque to break
then back off 1/2 turn
Old Feb 21, 2006 | 11:23 PM
B2FiNiTY's Avatar
Default Re: (43MA)
Sounds like the timing is off so it could either be the crank/cam gears or your distributer .
Old Feb 22, 2006 | 12:01 AM
ED7's Avatar
ED7
Default Re: (B2FiNiTY)
AHH jeez, you answered your own question.....not adjusting the valves would cause lots of problems. So do that first, and that should fix everything. I dont understamd why you wouldnt adjust the valves.
Old Feb 22, 2006 | 09:47 AM
handa's Avatar
Default Re: (ED7)
tada!!! juss switched the TPS and MAP sensor around, runs smooth like warm knife through a stick of butter. thanks D
Old Feb 22, 2006 | 09:50 AM
AssPenny's Avatar
Default Re: (handa)
That D... He's a smart fawker sometimes
Old Feb 22, 2006 | 11:30 AM
Dave-ROR's Avatar
Default Re: (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">That D... He's a smart fawker sometimes </TD></TR></TABLE>
Well and he's done that at least once.. as have I
I like all the "adjust your valves, DUH!" people though.
Old Feb 22, 2006 | 04:16 PM
D's Avatar
D
Default Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">tada!!! juss switched the TPS and MAP sensor around, runs smooth like warm knife through a stick of butter. thanks D </TD></TR></TABLE>
Old Feb 22, 2006 | 07:01 PM
handa's Avatar
Default Re: (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">
I like all the "adjust your valves, DUH!" people though.</TD></TR></TABLE>
I second that
Bumteg
Feb 3, 2009 11:00 AM
blowme
May 17, 2005 04:48 PM
wangan_DA9
Nov 1, 2004 06:39 PM
cRxAuDio
Sep 10, 2003 01:18 AM
