BIZARRE Crank/No Start. Please Help.
Old Feb 21, 2006 | 04:17 PM
93civicd16z's Avatar
Default BIZARRE Crank/No Start. Please Help.
I have a 1993 Civic EX. When I bought it, the timing belt was clacking, so I replaced the timing belt and the tensioner. I was driving it on the freeway and all of a sudden it made a loud noise like it hit VTEC, then died. I had to have it towed home and it hasn't started since. When I got it home I checked the compression and there was none. So I replaced the head. Checked the compression again with the new head and now I have good numbers. Spark and fuel are both present, but the car won't even try to start. I replaced the computer. If I pull the spark plugs, they're soaked with gas. I pulled out the injectors and kicked the fuel pump on and off but no fuel was leaking.
If anybody could please point me in the right direction, I don't even know what else to check. I've been working on this for a month and I'm pulling my hair out.
Thanks!
Old Feb 21, 2006 | 04:35 PM
theleftis's Avatar
Default Re: BIZARRE Crank/No Start. Please Help. (93civicd16z)
did you try searchin this, i'm sure there's info on this somewhere, but anywayy did u check to see if there's a spark at the plugs if not then chesk your lines again you could and check over your timing.
Old Feb 21, 2006 | 05:02 PM
crazyhondafanatic1's Avatar
Default Re: BIZARRE Crank/No Start. Please Help. (theleftis)
Bump
Old Feb 21, 2006 | 05:48 PM
JSPECSIR's Avatar
Default Re: BIZARRE Crank/No Start. Please Help. (crazyhondafanatic1)
did you check to see if the plugs are sparking.
Old Feb 21, 2006 | 05:52 PM
Default Re: BIZARRE Crank/No Start. Please Help. (5THGENSI)
Yeah, I have spark
Old Feb 21, 2006 | 05:58 PM
Jmunk's Avatar
Is your timing right ?
Old Feb 21, 2006 | 06:14 PM
96-EJ6 B18C's Avatar
Default Re: (Jmunk)
Firing order???
Old Feb 22, 2006 | 10:10 AM
Default Re: (96-EJ6 B18C)
Yes, Yes, Yes. Bump.
Munkeyjdm86
Feb 4, 2014 07:21 AM
dc2doi
Jan 6, 2008 01:43 PM
rodvang
Dec 25, 2007 08:37 AM
erniecombs
Sep 26, 2007 06:21 AM
ericlee303
Apr 28, 2004 03:31 PM
