idle surges even after replacing iacv
Old Feb 21, 2006 | 02:53 PM
wilrock's Avatar
Default idle surges even after replacing iacv
i replaced my idle air control valve today because my 94 prelude si idle has been surging from 800-1500 back n forth...but it did not fix the problem..anyone have any other possible solutions to my problem...i cleaned my original iacv n didnt work so i bought another one thinking it was just broken
Old Feb 21, 2006 | 03:05 PM
petern101's Avatar
Default Re: idle surges even after replacing iacv (wilrock)
you know whats funny, i have a 94 SI (but with jdm h22)
and when i unplugged the vacuum hose that goes to the black box under your oem intake, i would get the surging idle, when i plugged it back into the box, normal idle
that probably isn't your problem because i have read alot about this, but it cured mine
gl with that
Old Feb 21, 2006 | 03:54 PM
snowblind7x's Avatar
Default Re: idle surges even after replacing iacv (petern101)
my surging idle was fixed by replacing the IM gasket.
Old Feb 21, 2006 | 04:31 PM
Cottonwoodz's Avatar
Try, screwing in the TB Idle screw all the way in, and adjust from their...Set Idle at 800-850 somewheres about..
Most likely your Idle screw backed out(beep-beep) of the TB... Or you have a vaccum leak somewheres in your vac hose's
Old Feb 22, 2006 | 10:59 PM
wilrock's Avatar
Default Re: idle surges even after replacing iacv (Cottonwoodz)
aite imma try tomorrow..hopefully it owuld work...
Old Feb 23, 2006 | 12:00 AM
JDM4DRACCORD's Avatar
Check your Cold Start. Thats most likely the problem
Old Feb 23, 2006 | 03:43 AM
championshipwhite93si's Avatar
Default Re: (JDM4DRACCORD)
if all else fails bleed your coolant as well. probably got some air bubbles in the when you were replacing the iacv
Old Feb 24, 2006 | 04:23 AM
Dai_Ca_Vietnam_H22a4's Avatar
The same thing happen to my car. On the throttlebody there is a fast idle control valve or assembly. Remove that part from the throttlebody. Then remove one of the ends, I don't remember which side. Well, there is a plastic or wax screw inside. Screw the screw all the way in. That screw is adjusted at the factory but over time it unscrews itself out. I hope this help.
Old Feb 24, 2006 | 11:45 AM
Honda Sport's Avatar
Default Re: idle surges even after replacing iacv (Dai_Ca_Vietnam_H22a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dai_Ca_Vietnam_H22a4 &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happen to my car. On the throttlebody there is a fast idle control valve or assembly. Remove that part from the throttlebody. Then remove one of the ends, I don't remember which side. Well, there is a plastic or wax screw inside. Screw the screw all the way in. That screw is adjusted at the factory but over time it unscrews itself out. I hope this help.</TD></TR></TABLE>
I was going to suggest this too.
fast idle control valve helps control idle when the motor is cold. does this happen when the motor is cold or warmed up to operating temp?
Old Feb 24, 2006 | 12:21 PM
wilrock's Avatar
Default Re: idle surges even after replacing iacv (Honda Sport)
when i first turn on the car it idles very high...1500-2000...then when it warms up n drops thats when the surging thing comes on...
Old Feb 24, 2006 | 12:23 PM
sounds like a vacuum leak somewhere. check all vacuum lines, manifold gaskets, etc.
Old Feb 24, 2006 | 02:48 PM
wilrock's Avatar
Default Re: (Honda Sport)
uhhh stupid question but where is all that lol
Old Feb 24, 2006 | 08:56 PM
eluder33's Avatar
Default Re: (wilrock)
there is a fast idle valve under the throttle body (at the 6 o'clock position) and a idle air control valve on the front side of your intake manifold (its got an electrical plug and two coolant hoses running to it) clean the mesh screen in this one and replace the old dried out seals (3 of them) thats what was wrong with mine
Old Feb 27, 2006 | 01:22 PM
wilrock's Avatar
Default Re: (mattman33)
yea i replaced the iacv n it didnt do nothin..is the fast idle control valve the piece thats sort of RIGHT under the intake manifold like right under the intake pipe? cuz i took a piece off that i thought was the fast idle ..it had a spring in it but it didnt have a wax screw that im suppose to screw back in..there was no screws in it
Old Feb 27, 2006 | 01:40 PM
Komakazi_830's Avatar
check all of your hoses
RinzEG6
Nov 24, 2014 12:02 PM
dc4b20
22
Dec 3, 2012 09:54 PM
