B16 bucking at half throttle???
Old Mar 28, 2002 | 08:25 AM
gatesrex91's Avatar
Default B16 bucking at half throttle???
My b16 (91 CRXhf) is bucking really hard when driven at half throttle, but it is smooth at full throttle. The ecu is flashing a code 14 (electronic air control) but i do not think that this would be the cause of this problem. I think it may be the TPS sensors but i am not sure how to rectify this if that is the case (unless it needs new sensors). If any of you b16A drivers out there have any suggestions on how to fix this problem then I would really appreciate it
Tyler
Old Mar 28, 2002 | 09:02 AM
gatesrex91's Avatar
Default Re: B16 bucking at half throttle??? (gatesrex91)
Cmon guys, someone has gotta know sh*t about b16 swaps around here, i really need some help with this
Tyler
Old Mar 28, 2002 | 09:20 AM
l's Avatar
l
TTT
my car idles fine,.... full throttle seems fine but when i have it about 3000rpm and steady it shakes like a mother and missfires etc.....
Old Mar 28, 2002 | 09:40 PM
customx_'s Avatar
New User
any solutions?
Old Mar 28, 2002 | 09:49 PM
SUMORex's Avatar
Default Re: B16 bucking at half throttle??? (mindtrix)
i have the answer for you.... i hope.. i really think this is it....
ADJUST YOUR TPS SENSOR....
Get a digital volt meter and make sure your output is .45
Hope that works.... If you dont have a volt meter, just move it ever so slightly in different positions and drive it....
Old Mar 28, 2002 | 09:53 PM
CRexDX's Avatar
Default Re: B16 bucking at half throttle??? (SUMORex)
my d16z was doing the same thing...come to find out i had the wires backwards on the iac
stageonedc2
Sep 9, 2011 04:35 AM
B16Ben
Aug 29, 2011 02:54 PM
slow91ef
Dec 8, 2007 09:50 AM
insomniac791
Oct 4, 2003 09:16 PM
