Suspension & Brakes Theory, alignment, spring rates....
tires get rubbed by rear lip????
Old Feb 21, 2006 | 01:52 PM
mouch33's Avatar
Default tires get rubbed by rear lip????
I have some after market rims on my car(which I can't remember the numbers right now I'll post them when I get off work) They have a 7 inch contact patch as opposed to my 5 inches with my stock rims. I also have the tokico HP shocks and springs
(http://cgi.ebay.com/ebaymotors/TOKIC...38151466QQrdZ1)
When I put my bigger rims on the very outside edge of the tire gets rubbed by the lip of the wheel well. Is this because the springs or struts are to weak because I don't have this problem in the front. I do plan on getting a rear sway bar( would this help) or is there something else I'm missing. I love the bigger tires cause I can take any turn at any speed and the car handles like its on rails. Any help is great because I don't want to completely ruin the tires.
Old Feb 21, 2006 | 02:00 PM
8520's Avatar
Default Re: tires get rubbed by rear lip???? (mouch33)
How low are you? Camber kit or no?
Old Feb 21, 2006 | 02:06 PM
mouch33's Avatar
Default Re: tires get rubbed by rear lip???? (got_no_sol)
it's lowered 1.25 inches. no camber kit. I had it aligned with the smaller 13in rims, the bigger ones are 15's
Old Feb 21, 2006 | 02:15 PM
mouch33's Avatar
The tires are khumo(sp) ecsta 195 50R 15 82H
Old Feb 21, 2006 | 02:17 PM
8520's Avatar
I have to wonder if it's your offset. More specs on rims please
Old Feb 21, 2006 | 02:23 PM
mouch33's Avatar
I'll have to get some pics up. Another reason I'd like to keep them is I like where the edges of the tires are compared to the body. I think it looks nice. I'll have to wait till I'm off work before I can get the specs on the rims because i bought them from a friend and I don't know what the offset is.
by the way the car is an 89 civic dx hatch.
Modified by mouch33 at 6:40 PM 2/21/2006
Old Feb 21, 2006 | 05:45 PM
mouch33's Avatar
I took off one rim and couldn't find anything that looked like the offset numbers all I found was PRIME 15x7 5 309 48 S. I tried to measure it but I think I came up with a 38 mil positive offset. (7 in rim - 4in) / 2 or (177mm - 101mm) / 2. The wheel sticks out maybe a half in from the edge off the wheel well.
Old Feb 22, 2006 | 05:08 PM
8520's Avatar
Sounds like you have wrong size wheels, and your main problem is offset. A lot of negative camber would fix this, but then it would look like ****
You have any pics btw?
sh!ft
Jul 28, 2011 08:46 PM
theslugbug
Oct 18, 2010 07:36 PM
CDEEE5
Oct 9, 2005 05:54 PM
marc-111
Apr 3, 2005 09:41 AM
