New gears, at TDC, won't start
Old Feb 21, 2006 | 12:21 PM
fast_honda's Avatar
Default New gears, at TDC, won't start
I installed AEM cam gears over the weekend and now the car won't start. The Crankshaft is at TDC, the Cams are at TDC, and the cam gears are set at "0". Today I'm going to charge my battery just in case that's the problem, and if that doesn't work, I'll make sure the crank is at TDC on the compression stroke, it might be on the exhaust stroke, but it shouldn't matter anyway if I've already set the cams at TDC should it? HELP me
Old Feb 21, 2006 | 12:33 PM
PrecisionH23a's Avatar
Default Re: New gears, at TDC, won't start (fast_honda)
It could be off a tooth. Some of the aftermarket cam gears markings are off and you have to compensate for it by advancing/retarding the camshaft.
Old Feb 21, 2006 | 12:37 PM
championshipwhite93si's Avatar
Default Re: New gears, at TDC, won't start (PrecisionH23a)
does it crank over like it wants to start. if so its not the battery.
Old Feb 21, 2006 | 12:46 PM
fast_honda's Avatar
Default Re: New gears, at TDC, won't start (championshipwhite93si)
It did the first day, but not the second day. It still turns the belt, but doesn't sound like it wants to start, it's down to a soft purr, which tells me it mights be low on battery juice.
Old Feb 22, 2006 | 04:25 AM
try jumping it or getting a new battery. then go from there
Old Feb 22, 2006 | 12:23 PM
fast_honda's Avatar
I got it started today, wasn't the battery, just had to get the flywheel at TDC through the timing window. It started but it's a little noisy, probably due to some overlap, so I'm going to adjust the cams some more today. It's making alot of chatter, is it the valves?
vtec69
Jan 17, 2003 03:30 PM
vtec69
Jan 16, 2003 07:09 AM
vtec69
Jan 16, 2003 07:07 AM
Lei Siew Long
Sep 30, 2001 04:26 PM
