Honda S2000 Honda S2000
2000 S2k headgasket thickness?????
Old Feb 21, 2006 | 11:47 AM
Minh826's Avatar
Default 2000 S2k headgasket thickness?????
Does anybody know what's the stock thickness of a OE headgasket on a 2000 2SK is? Thanks
Old Feb 21, 2006 | 12:23 PM
kane.s2k's Avatar
http://www.s2000turbo.com/tech/headgasket.htm
Old Feb 21, 2006 | 01:34 PM
mellowhead's Avatar
Default Re: (kane.s2k)
so what does changing the compression ratio due for you? Is this for adding turbos or different mods?
Old Feb 21, 2006 | 02:20 PM
Minh826's Avatar
Thanks KANE.S2K That really helped me out. I got a blown supercharged s2k that We are rebuilding and that lil info. helped out alot.. thanks again
Old Feb 21, 2006 | 02:23 PM
SuzukaBlueAP2's Avatar
Default Re: (mellowhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead &raquo;</TD></TR><TR><TD CLASS="quote">so what does changing the compression ratio due for you? Is this for adding turbos or different mods? </TD></TR></TABLE>
lower compression = slightly larger margin for error when tuning FI. That's about it.
And the headgasket is not the (safest) route to go to raise or lower compression ratio. It should be done with a piston change.
Old Feb 21, 2006 | 05:32 PM
Atheist's Avatar
Default Re: (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">lower compression = slightly larger margin for error when tuning FI. That's about it.
And the headgasket is not the (safest) route to go to raise or lower compression ratio. It should be done with a piston change.</TD></TR></TABLE>
Thats really not true, taking away an OE build for lower comp pistons is actually pretty crazy when you can do it with a HG. In some gases a HG is not the way to go, but overall, it works pretty well.
Old Feb 21, 2006 | 08:02 PM
Default Re: (Atheist)
Agreed, Athiest. I guess i was just jumping to lower / raising comp. ratio for a big build.
dc4teg95
Nov 6, 2007 04:18 AM
EH-3
Nov 11, 2005 11:28 AM
peel17
May 29, 2005 01:19 AM
1.8T_EG
Jul 6, 2004 08:27 AM
020
Sep 30, 2002 07:52 PM
